*Official Release* RSI Triple Fuel Pump Hanger for C6 and C5 FFS Corvette's
#141
Not to split hairs with you... but if your car is making more rhan 500 at the wheels... the rails and injectors will feel a difference in pressure if they are tuned with 2 pumps worth of flow and pressure... and then taken down to one. For instance... what might require 90% duty cycle with one pump may only require 80% with 2 pumps if the one pump is nearing its limit. Ask any tuner... this is enough to destroy your motor.
Or you can live in denial... and tell me im wrong again
#142
If you take the time to do some homework.... youll notice i built a fuel system about 5 years ago that put 2 pumps... in each tank... and had a slosh line between the base of the 2 tanks so they would equalize in height... eliminating the syphon pump in passenger tank.
My point is I actually have experience in this topic... I build the fuel system and see what happens to duty cycles of injectors and pressures when fuel pumps are added and subtracted in real time.
I don't think it's fair to people with thousands of dollars invested in a motor to comfort them that when a single pump fails... Life going to be just fine because you're running hp tuners. So is everyone... Congratulations.
If your car can run on one pump at wot... Why are you even in this thread? Or spending money on this kit? Please read what you wrote and hold off on telling me I'm wrong... It's offensive when I'm trying to brainstorm to refine this system so I can implement it into my car and not have to play Russian roulette ever time I push my gas pedal down... Hoping my engine isn't about to detoonate
#143
Does anyone know the fitting and hose manufacturer RSI use in their kits? there is a text GGGG on every fitting..
Or is it safe to use any fittings, is it matter??
Thanks in advance!!
Thanks in advance!!
#144
It looks like those are for use with Super-flex PTFE-lined hose.
BJK
#146
Do a fore setup.
#147
Received 1,194 Likes
St. Jude Donor '15
Everyone does seem to love the Fore setups....
