FI with A6: not shifting properly at WOT
My '07 has a A&A Vortech SC making around 530 rwhp and my A6 won't auto shift from 2nd gear to 3rd at WOT without hitting the rev limiter. I was having the same problem on the 1-2 shift but my tuner lowered the shift point RPM as well as the shift point MPH and now the 1-2 shift is fine. He did the same thing on the 2-3 shift but so far it hasn't helped. I think he set it to shift at 6300 RPM but it still goes past that and hits the limiter. This issue happens in all modes, Drive and Sport (auto shift mode) and with TC turned on and off and in Comp mode as well as all nannies off mode. Has anyone else had this problem and if so, can you tell me what your RPM and MPH settings are for the 2-3 shift (with 2.56 gears)? Or, any other recommendations to resolve this issue? Thank you in advance for any suggestions.
Supporting Vendor
I had a similar problem with my 97 when I went FI. Turned out to be a mechanical issue with the transmission itself (something beyond my comprehension) I hope yours is not as deep of an issue.
Sorry to say sounds like your A6 may already be hurt. If the tune changes didn't help the shifts it's most likely internal. Get a hold of Mike @ Century trans if you decide to get it re-built. He is a forum sponsor now I think.
Location: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Thanks guys for your thoughts. Yeah, it could be an internal mechanical problem. I'm prepared to send it off to Century if it turns out to be the problem. I'm hopeful that it's just a tuning issue since it was also doing the same thing on the 1-2 shift and now it shifts to 2nd like it's supposed to after getting lucky on the tune changes.
Subfloor, you have a PM. Can you fit me in this week for a trans tune checkup?
If it was a clutch pack issue, wouldn't that also show up when shifting manually? I can keep it off the rev limiter in Sport mode when shifting at WOT manually. (I just can't shift it consistently that way since it revs about 500 rpm past the point when I paddle it).
when mine was going out, it shifted perfectly fine in manual mode, just wot in auto mode showed the signs.. give it a little more time, you will lost 3rd all together.. in fact your post describes exactly what happens when your packs start to go out..
I had the same problem with my A6. You might raise the rev limiter 2-300 rpms. Lingenfelter lowered the shift point rpm, shift mph (by 2-3 mph), and then increased the rev limiter 300 rpms. My A6 shifts well at WOT in all gears.
That sounds like an excellent idea to try. We did lower the shift point rpm and the shift mph by 2-3 mph but we didn't try raising the rev limiter rpm yet. I will talk to my tuner about giving that a try and will report if that cured the problem. If it doesn't cure it, I may be having to get a new clutch pack. I don't run drag radials or slicks so will be disappointed if the clutch pack has failed already.
Hopefully that will solve your problem.............
I would be suprised if your A6 needed rebuilding already (since you don't run "sticky" tires). Mine is still going strong after 4 years with 550 rwhp/520 rwtq in front of it.
If however your clutches are in fact gone, I found out the hard way that no matter how high you raise the rev-limiter the engine will just keep going up and up and still won't shift.
I wanted to thank everyone for their suggestions and also give you an update in case it happens to anyone else with the A6. We found out that it was indeed a tuning issue and not the clutches. If I remember my tuner's comments correctly, the 3-2 down-shift mph setting was set higher than the up-shift mph setting which is a no-no. He changed that and now it shifts just like it should at WOT. He also turned Torque Management off and now it shifts quickly without the lag. Thanks again for the suggestions.
