YSi or TTix .. Street Car??
#41
Turbo fans !!!
I wanted your thoughts on this
Would you prefer using a "Garrat turbo" unit instead of a "Turbonotics Turbo" unit?
The Garrats are top in the industry .. not saying that Turbonotics aren't
but I was just wondering
-Moe
-Moe
#42
I've always felt that for a street driven car, water cooling is a big plus and can add longevity to the turbos.
Might cost a bit more for additional lines and fittings, but I'd have it no other way.
Now, if they can supply Garrett's to fit, then it is an option to consider, but I would certainly use the Turbonetics, too.
#43
Personally, I'd use whatever TTiX supplies with the kit, but I think it would be a good choice to add the water cooled option to the turbos, if possible.
thanks for pointing that out man
#45
I believe there are two types of housings available, a "dry" and a "wet".
What they do is tap into the cooling locations on the side of each cylinder head, and create a "loop" for the coolant, in and out of each turbo, using the coolant flow path thru the engine.
Similar to the way the APS TT kit is designed.
They can use braided teflon hose and AN fittings to put it all together.
It will add some cost to the setup.
#47
First, you need to specify to Turbo Technologies that you want the turbos set up to accept water cooling.
definitely asking for the wet one
#48
My wires cost more than my engine.
My stereo cost more than my corvette mods and all.
I never go by 'worth it' judgements because most people would say spending 15k in mods on a car isn't 'worth it'.
#49
Oh and - $1Mil challenge
#50
In my oppinion get the turbo manifolds and the down pipes coated to keep the heat down in the engine bay. I had the bottom mount APS design and thought engine bay temps would be fine. They weren't. Got the manifolds coated first. Then the down pipes. Huge temp drop in the engine bay after each.
Part of the problem was 110 degree Sacramento summer heat and traffic. If your going to see +90 degree days and want ice cold A/C then coat all your hot parts.
Brake boosting is key to taking the "off the hit" advantage of a N/A or S/C away. It takes practice and will take a big toll on your brakes but works wonder.
PM sent of video proof of how effective brake boosting can be.
#51
I've used "Jet Hot 2000" in the past and it was a good investment to keep underhood temps down.
#52
Thank you Sir!!!
#53
#54
but it kinda sucks that the whole build up takes a while
hopefully i'll be gone for a month and the car will be nice and running
#55
#57
Location: Greater Detroit Metro MI, when I'm not travelling.
I know you don't like hearing about every time you get taken, but this is the sad truth. You got ripped off. http://www.roger-russell.com/wire/wire.htm
Oh, and TTix all the way. If cost were no object I would do turbos.
#58
http://www.youtube.com/watch?v=PTKaopR89oQ
Blue line is with factory catback installed. Red is with Open X-pipe.
#60
Me like more
