***Mantic clutches in stock and on special!***
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
EASY ORDERING ONLINE WITH THE LINK BELOW. ADD ANY ACCESSORY TO YOUR ORDER AT THE SAME TIME!!!
http://www.eastcoastsupercharging.co...ategory_id=251
As many of you may already know, ECS has been using the Mantic line of clutches with great success for the last year. We have been slowly introducing them to the boards intentionally so we have plenty of our own feed back from our racers and daily driver customers so we know we are offering a sound product.
We have used these clutches in everything from road racers, to drag racers, to daily driven street cars, and the response has been very positive from everyone who has been using it! We now have many of them out there, so our feed back is on a lot of installs from several different shops and builds.
Basically I have not found a clutch other then these that offers such a stock like feel and disengagement for all type of driving, with good slip for the drag guys, and effortless high RPM disengagement up top for both the drag guys and the road racers.
This is not a stock pressure plate that is painted a vibrant color and the disc replaced! These are a well engineered clutch for performance use on and off the track.
Mantic street single with ER2 $755
This clutch is best suited for the stock replacement on cars ranging from stock to 600 HP. It comes with a throw out bearing and clutch alignment tool. Flywheel is also included, so you have everything necessary for a complete clutch install.
*Take into consideration the mileage and usage of your vehicle as to whether or not you should replace your pilot bearing and slave cylinder, which is not included. We can supply you with these items if needed. We offer stock slaves, and with remote bleeders installed as well.
What is ER2?
ER2 is a patent pending design which features a unique groove pattern CNC'd to the pressure plate. The groove has been designed to increase the Mean Effective Radius of the pressure plate and assist in heat dissipation. Thus increasing torque capacity by up to 8% compared to the same clutch without the ER2 design.
The Mantic single comes with a dual friction material pressure plate. the pressure plate side utilises an organic facing ring in contact with the ER2 surface, and a segmented cerametallic on the flywheel side. The cerametallic material offers a higher torque capacity, while the organic side offers better streetability. Yielding "the best of both worlds".
MANTIC 9000 series twin disc $1,749
Only ECS offers these with a pilot bearing, clutch bleeder kit and FREE shipping in the continental US!!
Mantic 9000 series clutches are twin disc, 9” (225mm) diameter modular clutches that are designed for high performance cars or track use. Mass is critical for a high performance clutch to produce the expected level of performance, and Mantic offers two levels of low mass clutches to allow you to optimize your vehicle performance to your personal driving style. They offer up to 1010ft lbs (1365nm) of torque drive capability.
Mantic 9000 series are low MOI (Moment of Inertia) twin disc clutches that offer a level of performance not only superior to a single disc unit, but also allow you to select options that best suit you.All 9000 SERIES are made with premium quality materials designed to perform and last the distance.
The key to the 9000 SERIES is the street drivability of the Sprung Street Cerametallic discs. These suit high performance engines and enthusiastic driving styles, while allowing excellent drivability when needed. Low pedal effort is another bonus from the 9000 SERIES.
Mantic also offers a triple for the high HP crowd! Capable of holding 1500 ft lbs of TQ, yet still has a nice pedal feel for daily driving conditions.
The triple disc sells for 2,495
Thanks for your interest
These prices are for the Cerimetallic version, which we have found to be the best fit for the Corvette, be aware when comparison shopping to not be quoted for the organic version which is less expensive!
What is ER2?
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
Here are some pics of the 9000 series twin, and underneath those are the ER2 pressure plate for the single disc.
I have had a handful of questions on the twin disc clutches, so hopefully this answers many of them for you.
The 9000 twin disc is a billet pressure plate and the assembly is SFI approved.
There are four levels to the 9000 series, but we stock the sprung street cerametallic mainly. The "sprung" part of that is the springs you see on the discs in the center which makes the clutch a little more "streetable". That is the assembly that I would recommend for 98% of the cars on this forum.
Before I even list off all the options, let me make it clear all of these clutches have a great pedal feel to them, even the most "race" option, is not bad compared to most aftermarket clutches, but Mantic has been in the business of making OEM clutches, so their interpretation of streetable is OEM or better.
For the most streetable assembly Mantic makes there is the 9000 series full organic sprung. We have sold these to guys who have no intention of racing or heavy slipping off the line, but want a clutch that can hold a lot of power and literally feel better then a stock clutch IMO.
Our most common sale as I said is the 9000 series sprung street ceramettallic, this is a sprung center button type disc that offers a level of performance above organic discs, while offering little negative compromise for street use.
One step up from there performance wise is the Rigid Street Ceramettallic. This is a rigid, non sprung center disc, but with a cushioned button type disc that allows for a harder driving style with the best compromise for pure performance and driveability.
Last is the Rigid track paddle. This has a solid center, non cushioned metallic disc, designed for pure performance. This clutch offers little compromise, engagement is sudden which limits the chance of slippage. It is recommended for road race track use only.
The full assemblies weight 32-34 lbs depending on which one you go with.
Thanks for all the orders guys!
It is lighter then many single disc clutches, but not as light as the twin disc is. Personally I'm not a fan of a very lightweight clutch on a street car, but that is just my opinion.
Hope that helps.
Restocked, also trying one of the 7000 series tripple disc race clutches too. I'll post up our review.
Thats a little over sorry, I'm sure it would hold, but you dont want to be on the edge of your clutch. You would be better off with a triple disc clutch for your application. I would suggest the RPS triple.
The twin 9000 series clutch is best suited for stock to 8-900 ft lbs of TQ IMO. 1000ft lbs is going to require a clutch at a whole other level, which usually comes with a whole other pedal feel too, but it is what it is.
Thanks for asking though!
Restocked with two more pallets worth of clutches! Thanks for all the orders guys, we greatly appreciate it and are glad to hear your happy with your purchase.
Yes it is, we actually have some great deals this week with the launch of our new web site too!
You can order right on line, or feel free to call us if you have any questions. 609-752-0321
http://www.eastcoastsupercharging.co...ge=shop.browse
Restocked yet again, thanks for the sales guys.
http://www.eastcoastsupercharging.co...ategory_id=256
