OFFICIAL A&A SUPERCHARGERS Q&A thread
#481
Platinum Supporting Vendor
Thanks Josh. My tuner is recommending a fuel system upgrade, as a minimum putting in the C6 Z06 in tank pump. I just wanted a second opinion. Also, my tuner won't do methanol injection as they prefer an E85 conversion for reliability, however, that seems quite a bit more expensive than installing a meth kit.
#482
Thought I would ask the expert to make sure I got good advice so here goes:
We live at 7,000 feet so if a super charger system is installed and tuned for our elevation what happens when I drive down to sea level, which happens a couple of times a year? As elevation decreases the car would be running leaner and leaner. Will it have the ability to reprogram its self?
#483
#484
For normally aspirated applications, everyone says the LS2 intake manifold is a poor design. However, in this thread I have read that replacing the LS2 intake manifold on a supercharged application doesn't give much, if any, benefit. Why is it that the LS2 intake manifold doesn't hinder the performance in a supercharged application?
#485
#486
Received 1,194 Likes
St. Jude Donor '15
If the car is tuned correctly with the 02 sensors still set to go into Closed Loop operation including Long Term Fuel Trims the PCM will compensate by adding fuel during part throttle driving and if the LTFTs are positive(near sea level) and then you go WOT it will add that positive percentage of fuel to the already dialed in settings from your "tuned" altitude. Shouldn't be a problem for you.
#487
i just purchased a C5 zo6 black out supercharger kit that was bolted on a car, tuned and the car got rear ended and was totalled.
The car i intend to put this supercharger on is a 2005 C6.
Will the C5 zo6 brackets, intercooler and everything else work on my Corvette or will I need to purchase the c6 brackets off of A&A site?
thanks for the information !
#488
c5 zo6 A & A kit in C6
I just purchased a slightly used A & A supercharger blacked out kit.
The kit was bolted on a c5 Zo6, tuned and the car got rear ended.
I purchased this from a gentlemen needing some money in an unfortunate time.
my questions is will this kit bolt on to an 05 C6 Z-51 car?
If not what all do i need to purchase additionally from A&A?
I have all
Brackets, belt, pulleys, a big bubba BOV i have.
Vortech V3 head unit.
Do i just need a new crank pin kit, a new oil feed line kit ?
some insite here would be fantastic!!!!
thanks in advance.
Brandon Cogdill
I have all
thanks in advance.
Brandon Cogdill
#489
I have all
thanks in advance.
Brandon Cogdill
I have all
thanks in advance.
Brandon Cogdill
josh@aacorvette.com
805-278-4107
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
#490
Josh
I have a stock 07 Z51 with an A&A Si kit and stock 3.8 pulley. I'm really happy with the way the car runs. But what would be my next one, two or three steps to increase power and minimizing multiple tunes. I have some ideals but would like to hear from you guys. Doing a little day dreaming. Thanks
#491
Josh
-Add blower can & springs.
-Add AlkyControl Meth kit.
-Pulley and belt swap to 3.6"
-Tune it and gain another 80-100rwhp.
#492
First talk to your Tuner to see what power level they are comfortable pushing it to on pump gas. Then ask if they like to use Meth or E85.
#493
Rather than space down the radiator cradle, I think I am going to move down the brackets themselves.
Can anyone tell me exactly how much lower it gets moved down normally ?
#494
#495
Thanks Josh..
Just some info for anyone trying to use a C5 kit on a C6. I got such a deal on the kit I couldn't refuse.
I know I'm nuts but before changing my water pump or buying a C6 bracket I decided to try and use the C5 bracket with on my C6 with the stock pump.
It wasn't easy, and a bit nerve wracking, but it can be done. I figured worst come to worse I had to change the pump anyways, so we went at it with a grinder. With some grinding on the pump, and a little on the bracket, we got it to fit perfectly.
#496
Cruising
Josh
#497
Nice mph. High boost for pump gas though, even 94.
#498
In the instructions for the secondary drive it says that the power steering cooler will not be reused. Is there a reason for that. I am in the middle of an install and can not see why it is not just put back.
#499
Because it's usually in the way of tubing exiting the blower and since it just gets hot air from the fan/radiator blown across it, it doesn't really cool anything, lol.
#500
Hey Josh, remind me why Andy went with the NT01's instead of NT05R's on his blown C7 (isn't that his actual license plate BTW)?
And when does Andy get his C7Z?
