OFFICIAL A&A SUPERCHARGERS Q&A thread
#561
Platinum Supporting Vendor
I'm trying to spec out all costs, to get a stock c6 z06 to 600-650rwhp, what all would be needed? It looks like one of the DeWitts radiators, not sure which. Heads seem like a must on the z06's due to the valve issue.
What do you recommend from there? Headers? One of your stage 1-4 cams? Also on the cams, what's a good one for a noticeable lope without hurting "drivability" or gas mileage?
so I can get you more info and discuss specifics.
#563
Aftermarket cold air intake with A&A Corvette Suoercharger system
Is there any hp benefit to using an aftermarket cold air intake with my A&A V-3 Si kit (purchased new in 2014)?
At what hp level would the air filter assembly from the A&A V-3 Si kit become a restriction that could be improved upon?
#564
Our SC air filter and dongle inlet work very well. I don't usually see a big benefit on power gains until you are pushing over 850rwhp like when using the big Ysi SC. Then you can make a custom 4" short inlet and see some gains past the 850rwhp level.
#566
I was reading through the C7 section just now and someone said the A&A kits came with a new harmonic balancer.
I didn't do the install on my C6 so am wondering, did the kit they installed on my car last month also include a new harmonic balancer?
#567
Hey Josh,
Just curious, what size fuel injectors come with your V3 Si trim kit with 3.8 pulley. This is for a 2008 Z51 Corvette that was installed in September of 2014 at A&A Corvettes. I thought I heard #62, then in a past post Andy mention 80#. Who is the manufacturer of the injectors?
BTW: The car is running strong!
Thanks.
Thanks.
#568
Typically a C5 or C6 just gets the crank pinned during install, unless the balancer needs to be replaced at that time.
#569
Hey Josh,
Thanks.
Thanks.
#571
supercharged and codes..?
I hope Im posting in the right forum..:
My husband and I are looking at this 1998 C5 with mods for sale 76K miles $16,500.
We did test drive the vette it was was awesome!...the codes that did not clear and are C Current are:
B0361 HVAC
B0441 HVAC the AC was not working properly
RFA C2120 (tire monitor system)
PCM 0748 (Pres. Control Solenoid) ?
This last one kinda worries me because the transm. shifted HARD from 1st to Second and the Dealership is saying that its because of the High performance kit and mods..it sets the code off but its nothing and that's normal.
What do YOU think?
Are all of those codes expensive and big deal to fix?
Cheers
Here's some pics
B0361 HVAC
What do YOU think?
Cheers
Here's some pics
#572
Received 1,193 Likes
St. Jude Donor '15
B0361 HVAC
What do YOU think?
Cheers
Here's some pics
B0361 HVAC
What do YOU think?
Cheers
Here's some pics
The C2120 is likely just a tire pressure sensor, not a big deal. The batteries die in the sensors every few years, they're fairly cheap to replace (~$50 for the sensor and have to remove the tire from the wheel to install)
I found this on the transmission one. Not sure if it helps or not.
http://www.ls2.com/boggs/a4/DTC%20P0748%203.8.htm
#574
Hey Josh, I am installing a meth kit on my zo6 and was told you guys can make me a new maf pipe with the maf sensor moved forward so I can install the meth nozzles and temp IAT sensor behind it.....is this possible?
#575
Call the shop and ask for me please.
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
#576
B0361 HVAC
What do YOU think?
B0361 HVAC
What do YOU think?
#577
Since our outside temperatures have increased I notice that sometimes after I attempt to start my car after a nice drive it takes longer to start. Almost sounds liked a minor case of vapor lock.
Thoughts?
Thoughts?
#578
On LS3/LS7 cars with the bigger 80# injectors that come in the kit, you probably just need the tune adjusted in the "start-up" settings to help it fire up quicker.
#579
Thanks, I stopped in at the shop today and the mechanic who installed the SC thought it might be a little rich at start up he adjusted the tune a little to add more air. Will give it a few days and see what the results are. Appreciate the advice.
#580
Ive been following this and reading a couple pages, but I really dont want to read 29 pages to find the answer.
How is routine maintenance affected with this kit? I.E. Oil changes, belts, filters, water pumps, etc etc...
Just got a 2010 M6 Grand Sport.. Coming from a 2012 Mustang 5.0 Supercharged, I need something to wake this baby up like i did the stang... But if routine maintenance becomes a pain, I may go with a TVS setup..
Thanks!
- Nick
Thanks!
- Nick
