OFFICIAL A&A SUPERCHARGERS Q&A thread
#621
Just put a nice stall in it and shave that 60ft down to a 1.55 and knock .5 off your 1/4 mile. That won't even require anymore power or upping the boost. Get a 3600 stall and never look back. The stock converter is holding you back from a great 60ft right now.
#622
Hi Josh,
I have your V-3 Si kit on my 05 C6 LS2.
What is the max rpm recommended for the impeller In This head unit and what is the multiplication ratio between drive gear and driven gear?
I currently have a 3.6" pulley and my engine's redline is about 6500 rpm.
What are my available choices for smaller blower pulleys and how close will that get me to the maximum recommended impeller rpm?
#623
Hi Josh,
http://www.vortechsuperchargers.com/page.php?id=33511
#624
Platinum Supporting Vendor
Hi Josh,
#625
Hey Josh! Has Andy gotten the smog certification for the C7 yet? Car is on order and will be built next month, and I will be picking it up at the beginning of September.
#626
#628
I wanted to post a quick review as a long-term A&A customer.
I've had the A&A supercharger package on my 2004 Z06 for two years now and have absolutely loved it. The car gets 700 bhp with the blower package which is about a 75% increase. The tune is very mild, not much timing was pulled. I've driven 40,000 miles with the blower and have not yet ran into a blower-induced issue. No engine problems. I have taken the car to 3 track day events and go WOT through about 10 gears per week. The car has almost 150,000 miles on it now and runs and drives as good as new. I have seen no decrease in reliability, which was my main concern when deciding to get this done in 2013.
#629
Hi Andy, I am looking for the Sheet metal that fits on both sides of the C6 Z06 stock radiator that funnels all of the air through the radiator and keeps air from going around it. is this the correct part that I'm looking for, or is this for the intercooler only?
http://www.aacorvette.com/supercharg...roducts_id=300
#630
You can order it right off the website.
#631
Received 1,194 Likes
St. Jude Donor '15
Any reason those wouldn't work with the other guys kit. I've been meaning to fab something like this up but haven't gotten around to it yet
#632
#633
I'm piecing together an A&A kit to spread the cost out over time. So far, I've got the blacked out v3 si head unit, and just picked up the intake dongle and filter used from a member on here.
The filter could use a cleaning as the PO had noted, what do you guys suggest to use for cleaning these filters? I've cleaned k&ns before and still have leftover cleaning spray and oil from cleaning filters in my other car, can I use them on your filter, or is there a better method?
#634
#635
Thanks for the great service Josh. Parts showed up just before I left town and look great.
#636
Hi Josh,
#637
A&A V2 kit modification
Hi Josh;
I have an A&A V2 kit with 3.8" pulley installed on my '05 LS2. In this configuration the car makes 7lbs of boost at 6500rpm. The car is tracked a few times a year (road-racing and drag racing). I'm planning on tacking this up to take this up to 15lbs of boost and add methane injection.
What do you suggest for a pulley size? (I'll be keeping with the 6500 engine redline).
Do you have any other advice?
eboch
eboch
#638
Hi Josh;
eboch
eboch
Or install cam/springs, headers, Meth kit, 3.125" pulley/belt, Secondary drive, 52mm BOV upgrade, external fuel system, and re-tune for big power.
#639
Thanks for this info Josh.
....yes, I did discuss with the tuner (Champion). He didn't seem that concerned as long as the meth kit was there ... and of course that it was appropriately tuned.
Approximately, what kind of boost would you think would come from the 3.4" pulley in this config (V2, A&A Stage II cam, 3" exhaust)?
thx
eboch
thx
eboch
#640
thx
eboch
thx
eboch
