OFFICIAL A&A SUPERCHARGERS Q&A thread
#721
Boost vs Timing
Hi Josh,
I have an 08 LS3 with 3.8" pulley, V3 Si trim that A&A installed. Besides the S/C the car is stock, including oem NPP exhaust, no meth and no headers. At the time of the install, the engine put down 581 rwhp, 13* timing and 10 psi. of boost. Since the S/C install, I had experience some audible detonation. Then, after the emission recall (added two small cats) I had the car retuned and timing was pulled to 10*. My tuner felt the car would run more efficient, if I dropped some boost (pulley up to 4") which he could then add more timing. The car ran 567 rwhp on the dyno with 10* of timing and 10 psi.of boost. I want to keep the car CARB legal and as stock as possible with the exception of the S/C kit. I know the added cats were no benefit.
We have 10* of timing without detonation and if I had to go lower in the future, I would be concerned with the loss of efficiency and catalytic longevity. My car was S/C 'd with 63k miles and currently 70k miles. I also had the engine de-carbed several times to reduce the chance of carbon buildup.
How much power would I lose going up to 4" pulley and let's assume we add couple more degrees of timing vs leaving it with 3.8" pulley and 10* timing? Would the car run more efficient with less boost and more timing?
Appreciate any suggestions.
#722
Platinum Supporting Vendor
Hi Josh,
Mike's LS3 (04-04-2016)
#725
#727
#728
#730
Or I think some guys were able to get the Powerbond Overdrive balancer PB081117-SC10 and it cleared.
#732
My 6 rib Gates Mirco-V K060910 HD Green Stripe belt needs replacing and all of the Gates belts I'm finding in that part number are called Fleetrunner and they are green in color. My belt is 4 years old is the fleetrunner green belts now the replacement belt? It does not look like the right belt to me. Is there a better different number belt than the K060910 belt now? PS from Jeg they have Gates K060910 but when you put the HD on the end making it a K060910 HD it changes to a AC Delco the parts salesman said that was the HD version.Thanks
#733
My 6 rib Gates Mirco-V K060910 HD Green Stripe belt needs replacing and all of the Gates belts I'm finding in that part number are called Fleetrunner and they are green in color. My belt is 4 years old is the fleetrunner green belts now the replacement belt? It does not look like the right belt to me. Is there a better different number belt than the K060910 belt now?Thanks
BowtieBilly1121 (05-23-2016)
#734
Josh,
I have a stock 07, LS 2,automatic, stock exhaust with NPP added. Your kit V3 si with a 3.8 pulley on 93 octane. My car runs great! What would you recommend for my next couple of steps performance wise? Thanks
#735
Or if you like to drag race a set of drag radials and a nice 3200-3600 stall with external trans cooler would be a great mod.
#736
Talk to the shop that tunes your vette and see if they like using AlkyControl meth injection and go down to a 3.6" pulley and shorter belt at the same time. Would make a few more psi and with the high octane of the meth could run a little more timing too.
#738
Josh, Think of going FI very soon. I think I would be happy right around the 600RWHP mark. I was thinking your SI trim with Methanol injection. Would defiantly appreciate your input! The car is 05 vert, Fast 102 intake, ported throttle body, Long Tube headers, High flow cats, Borla Atak, Holly fuel rails( don't do anything for power but sure look good) MSD Coils and wires, CAI (but that will go away) Elite Engineering catch can (with check valve), Monster LT1-S clutch. Thanks in advance for the information
#739
Do you have a shop you will be working with for the install and/or tuning?
You can email me instead if that's easier to keep track of. Email in my sig.
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
#740
I have the A&A v3si kit installed by you guys. I noticed that the charge pipe is pushing out the brake duct on the passenger side (Grand Sport). Is there any way around this? I've worn a hole in the brake duct now. Thanks!
