Stock Block / A&A Blower / 91 Octane + Meth: MAX RWHP?
I'm in Cali w/ crap 91 octane gas. Currently pushing about 640 rwhp through a stock block LS7 with cam, headers, A&A blower @ 5-6 PSI. Can I safely make more power with meth? If so, what can I expect?
Si-trim will make out around 71-720rwhp is you really push it.
IMPORTANT COMMENT ABOUT "RACING FUELS" Do you want to fill up your tank with alcohol free fuel? Pump gas in Ca is 10% alcohol. Alcohol has significant corrosion issues. If you have a car you don't drive often, you don't want alcohol in the fuel. The option is to buy alcohol free racing fuel. To buy an alcohol free fuel, don't buy racing fuels that are "oxygenated." Oxygenated is a code word for alcohol infused gasoline.
In the off chance that you might own a WWII P-51 fighter plane, you should know that you can buy 140 octane leaded aviation gasoline.
Also, in the early 1980's I had a clone L88 engine in my 1969. Milled the piston domes down 0.100 inches to get a 11.5:1 compression ratio. High octane Av Gas was a solution. I went and bought so many Jerry cans of AvGas at the Torrance Airport, that the guy at the AvGas station gave me a break. I'd pull my 69 Corvette around on the backside of a building and he'd fill me up with AvGas directly. I'm sure no way anyone would do this today.
What blower do you have? 740 out of t-trim is perfectly reasonable. 740rwhp out of a si-trim, not so much.
