A&A supercharger installed C6 Z06
St. Jude Donor '12-'13
I had the A&A supercharger installed by Rizza Racing Performance in Denver, Tuned by Ed Hutchings with High Tech Tuning
It dynoed 676WHP and 617 Torque with the Sc, tune and SW exhaust.
Awesome numbers!! I am looking at the same kit for a Z06 as well. Is that the T-trim? I am very curious to see what you think of it after driving it a while. Congrats!
It is the Si trim with a smaller 3.6" pully because I am in Denver over 5000ft above sea level.
It runs great, the SC is very quiet and it drives normally when not under boost. The rear tires have to be hot to handle the power with boost, it has hooked so hard on the street a few times it just makes me say it WOW.
I have Michelin Pilot sport cup non runflat tires and another set of MT drag radials I havent tried yet.
Cant wait to get it to the track and dragstrip
When it hooks up it pulls through first and second gears quick, look at the speedo after going into second and it is pulling past 100 in a matter of a few seconds in 2nd gear.
I looked into the trim level and found out I have the Si trim with a smaller pully. It works great as it was set up and tuned. I doubt I will ever need any more boost than it is giving the LS7
T-trim is larger and gives you more room to grow. An Si-trim would be maxed out with a 3.6" pulley. For an LS7 I would start with the T-trim.
Platinum Supporting Vendor
Great results! Both Ed's did a great job!! Glad to hear our kit WOW'd you...it tends to have that effect on people.
I'd also like to clear up some misinformation in this thread. The Si is not maxed out with a 3.60" pulley and a stock size balancer on a LS7. If you run a overdrive 8" balancer then that changes things.
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
[QUOTE=NospdLimit;1581469922]It is a blast to drive, it was stock though too! It is hard to maintain traction in 1st and 2nd, my Tires need to be good and hot.
im surprised it hook at all in 1st and 2nd
how much is byour boost exactly? 3.6 on a t-trim sound a lot for a stock ls7 even at your altitude
[QUOTE=timmyZ06;1581470610]
Im trying to figure out if it is a T trim, or SI, we discussed going with the T trim initially.
The only runs I made prior to the SC were with worn out Goodyear runflats, I ran a 13.2 at 111MPH with the tires spinning through most of first gear and again in second enough to loose time, not a very good before and after comparason.
I have MT drag Radials I will run next time, on the street I use the Pilot sport cup, non runflats.
Doug,
Glad you're enjoying your new power. Ed Hutchings called me the other day to check back in wondering if you were still having fun with it. I told him you were very pleased with what we were able to put together for you.
I may have a HyperDrive available if you want to come out to HPR this weekend for our NASA event and try a 20 minute session on the road course. If interested, call me on my cell and I can try to get it lined up for you for Sunday. Might help you to learn how to control all of that new found power.
Doug,
Actually I would love to Run it at High plains but our company has a booth at Bandimere speedway truck fest on Sunday I comitted too.
