1000whp+ capable fuel system for under $1500
After reading about various issues people were having with in-tank fuel pump solutions over the past few years, I really started to like the idea of a stock in-tank pump + big external pump more and more. Running the stock fuel pump in 'normal' driving conditions would ideally be more quiet, and potentially keep the fuel cooler as well.
As I dug into the parts needed to put something like this together I started making a list, and now that I've tracked down all the parts and fittings, I thought I'd share them so anyone else considering this path can save some time.
Here is a very basic diagram just to give an idea of where everything is going so the parts list makes a bit more sense.
Fuel feed/stock pump:
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&P roduct_Code=ATP-FTG-111&Category_Code=FUL (fitting to convert OEM fuel pump feed line to female -06 AN) ATP $15
http://www.summitracing.com/parts/SUM-220192B/ (-06 AN male to -06 AN male check valve) Summit $46
http://www.summitracing.com/parts/FRA-496107/ (-06 AN female to -08 AN female) Fragola $7
http://www.summitracing.com/parts/SUM-220109B/ (Y-block, -08 AN male) Summit $31
http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LPE& Product_Code=L750010103&Category_Code=P0 16 (OEM fuel pump regulator block off) $15
http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LPE& Product_Code=L750000103&Category_Code=P0 16 (OEM siphon jet regulator bypass) $22
Fuel feed continued/external pump:
ECS fuel block (attaches -08 AN and -06 AN male ports to fuel tank) ECS $189
http://aeroquip.cc/search.aspx?find=FCM1543+%2f+FBM1543 (-08 AN female 120* connector)$18
http://aeroquip.cc/fbv0800fc332-08aeroquipsocketlesspush-onhosehightempfc332-8.aspx (24” -08 AN e85 compatible fuel line) Aeroquip $9
ECS custom wiring harness with hobbs switch (turns on external magnafuel pump at __psi) ECS $79
http://www.ebay.com/itm/Magnafuel-Pro-Tuner-750-In-Line-Fuel-Pump-MP-4303-/330329836118?pt=Race_Car_Parts&hash=item 4ce9314a56&vxp=mtr (male -08 AN in/out) eBay $485
http://aeroquip.cc/search.aspx?find=FCM1523+%2f+FBM1523 (-08 AN female 45* connector) Aeroquip $11
http://aeroquip.cc/fbv0800fc332-08aeroquipsocketlesspush-onhosehightempfc332-8.aspx (12” -08 AN e85 compatible fuel line) Aeroquip $5
http://www.summitracing.com/parts/RUS-650103/ (-08 AN male to -08 AN male fuel filter)Russell $26
http://www.summitracing.com/parts/FRA-496108/ (-08 AN female to female adapter) Fragola $7
http://www.summitracing.com/parts/SUM-220193B/ (-08 AN male to -08 AN male check valve) Summit $48
http://www.summitracing.com/parts/FRA-496108/ (-08 AN female to female adapter that plugs into Y-block above) Fragola $7
http://www.summitracing.com/parts/SUM-220890/ (-08 AN female connector) Summit Racing $7
http://aeroquip.cc/fbc0800fcc0810-10ftlength.aspx (10 feet of braided, E85 compatible -08 AN fuel feed line) $70
http://www.summitracing.com/parts/EAR-840108ERL/ (-08 AN male connector) Earl’s $15
http://www.summitracing.com/parts/AEI-15118/ (fitting to convert fuel rail inlet to -08 AN) Aeromotive $38
Total for feed setup = $1,179
Fuel return:
http://www.summitracing.com/parts/FRA-497306/ (4AN female to 6AN male fittings to attached fuel rail test port to regulator) Fragola $7
http://www.summitracing.com/parts/AEI-13105/ (Boost reference fuel pressure regulator, remove feed -06 AN fitting and use fitting above) Aeromotive $170
http://www.summitracing.com/parts/FRA-498103/ 90* AN fitting (-06 AN female to -06 AN male) $13
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&P roduct_Code=ATP-FTG-111&Category_Code=FUL (fitting to convert OEM firewall feed line to female -06 AN) ATP $15
http://www.summitracing.com/parts/RUS-640853/ (fitting to convert original fuel feed near tank to -06 AN) Russell $17
http://aeroquip.cc/fcm1512-fbm1512.aspx (-06 AN female fitting) $5
http://aeroquip.cc/fbv0600fc332-06aeroquipsocketlesspush-onhosehightempfc332-6.aspx (12” -06 AN E85 compatible fuel return line) $4
http://aeroquip.cc/fcm1532-fbm1532.aspx (90* -06 AN female fitting) $9
Total for return setup = $240
That puts the total fuel system cost ~$1419.
Fuel return:
I still like the idea of the surge tank, just want to keep things simple for now. Depending on how things go with E85, I may add a big one just to get some extra fuel capacity.
On the hobbs switch I doubt I'd hear it over the exhaust and blower once I'm making enough boost to activate it
yup, definitely took a while to plan everything out and find the fittings that made it work. Hopefully it saves someone else some time when they look at doing a fuel system.
Received 1,194 Likes
St. Jude Donor '15
Bookmarked!
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Thats why our fuel systems cost what they cost. Personally I think just ordering an ECS stage 3 fuel system is the faster/easier answer though, but I might be biased.
Definitely. That's the next thing to upgrade probably if you're pushing big power. It's also another added expense I tried to cut out since stock rails handle lots of power.
I wonder if you could weld the fitting to the rail to make it stronger.
The ECS fuel block is pretty slick, but I was thinking about it, and since you'll have access to inside the tank while removing the stock fpr, you could use basic -08 AN and -06 AN bulkhead fittings. You'd lose the fuel sock on the '08, but save quite a bit of money.
http://www.summitracing.com/parts/SUM-220882/ (-08 AN fuel tank fitting) Summit $12
http://www.summitracing.com/parts/SUM-220682/ (-08 AN fuel tank fitting) Summit $10
So that drops the price to ~$1252
The secondary pump on an ECS kit only comes on under boost, so all you ever hear is the same noise level of stock.
Tell me about it...
Tell me about it...
I have a rsi state 3 setup. If I could go back I would just do what Doug said and get the ecs kit. I got to drop the tank again when I get home to fix the siphon pump.
And acctually you don't need the check valve in line with the Magnafuel 750. That gear pump doesn't back flow very well and just to LYK I"m not running any check valves, but you can if you want.
have there been any issues with plumbing out the bottom of the plastic tank w/ lack of a sump and all?
i assume you can go down to at least 5 gal long as your still filling from the passenger tank?
