Whcich Valvesprings for boosted STOCK LS2?
Which Valvesprings for boosted STOCK LS2?
I have been thinking of upgrading the valvesprings for added safety of the my valvetrain under boost and high RPM's! I have no plan of putting in a higher lift cam as the stock cam is working great, I mainly dont want to over srping the engine.... all I want is a good set of vs's to allow the engine to rev a little higher at this power level!
Stephen!
Stephen!
Patriot Performance 8401. Summit has them for a good price.
The Patriot Gold 8401 kit is a complete drop-in LS dual spring kit that consists of 16 Patriot Gold dual valve springs, 16 titanium retainers, 32 Super 7 machined locks, 16 .505 ID machined spring seats and 16 viton rubber valve stem seals. This kit will work with both stock and aftermarket rocker arms. No cutting or machining of the stock spring pocket is needed. Fits LS1, LS2, LS3, LS6 cylinder heads & one spring kit does a pair of cylinder heads.
Technical Specs:
• Installed Height: 1.800
• Max. Valve Spring Lift: 0.650
• Spring Pressure Closed: 135 lbs. @ 1.800
• Spring Pressure Open: 375 lbs. @ 1.150
• Coil Bind: 1.090
• Retainer Material: Titanium
Technical Specs:
• Coil Bind: 1.090
What kind of rpms do you guys think would be safe to stay under with stock bottom end as well? If could rev to 7k it would help my gearing issue a LOT!
Former Vendor
We sell Brian Tooley Racing springs with all our cam kits, there dual springs rated at .660 lift with lightweight retainers, comes with seats and seals and start for $220 a set to your door-and there made in the USA!!!!!
BT Racing is proud to introduce our new lightweight steel retainer dual spring kits. We have the lightest steel retainers on the market.
These new steel retainers combined with stock locks are within a half gram of the competitors titanium retainers and super 7 locks.
Stock locks are preferred in applications using stock rockers as they allow valve rotation, which is important to valve tip durability.
BTR Steel retainer and locks
Competitors titanium retainer and super 7 locks
You won't find a better spring combination for this money-why would anyone ever use a single.
FREE SHIPPING in the US!
Man it's crazy to see the steel retainers are about the same as the other titanium. Those super 7 locks are CHUNKY
I run the titanium Tooley ones and it's a nice kit, but for the money and a little more weight on the valvetrain I'd rock those steel retainer ones on anything thats not a crazy cam or high boost/harsh cam deal for sure.
I wish I knew what valve springs and valves my dad had installed before I got the car. I hit the 6500 rev limiter like a wall one time in 2nd gear.
I would love to knock the limiter up to 7k just so I'm right at 60mph in 1st.
