Boost a pump for Edelbrock E-Force question
[QUOTE=Motorhead-47;1582374037]Best place to get accurate boost measurement is the 1/8" plugged hole on the driver's side.
QUOTE]
Excellent,
I must be psychic because I knew you would have the answer with excellent pictures. I have found reference where to mount the BAP using the Racetronix harness but not where to connect the sensor so thanks for you diligence.
I think we should open a speed shop - I'll run the cash register!
QUOTE]
Excellent,
Excellent,
As for the speed shop..I'll man the keg tap and take charge of hiring the umbrella girls. Not that I've ever seen "Umbrella Girls" at a speed shop but I think it would help with customer traffic.
Are you thinking your low speed stumble problem is fuel pressure related?
No, fuel pressure is good. I'm hoping the stumble problem will be taken care soon. If Edlebrock can't get it fixed I'll find somebody that can or tune it myself. I'm seeing a 3.5" pulley in my near future.
I've tuned a few C4's including my own using the old Tuner Cat software. I've just never tuned one with a blower or MAF sensor. Also, the HP and EFIlive is expensive. SCT Advantage III GM pro racers software is only $350 and I already have the SCT hand held device and the live link Gen II data logger which was free. The good thing is their tech support says it will tune everything the others will. The bad thing is that help will be somewhat anemic on the forum.
Going to the Drag Strip Friday!!!
When you connect to the OBDII with data logging option do you loose the speedometer? Will automatic transmission shift above 3rd gear?
With SCT data logging you loose just about everything that reads out on the dash and it will not let the automatic trans shift above 3rd gear. I'm just curious if this is the norm.
Do you know if people post HP tuner files on line to learn from?
I did download the demo version of both EFIlive and HP tuners. I liked HP the best. I couldn't get the demo for EFIlive to work. Hp was complicated especially someone that was used to old TunerCat C4 software but I don't think it's beyond me.
What ever you do, do not blindly load anyone elses tune to your car. That is very risky. If you do get hptuners and can post up your tune, we can look at it and possibly help.
That's good to know. I sure thank you guys for the info. It will be some time before I chunk out the change for HP Tuners. Probably be the new year before I buy anything for myself. A lot depends on how well Edelbrock does on the mid range stumble.
Thanks again!
Based on what I know now if I were to choose again I'd go with EFILive. There are several valuable tuning tools in EFILive that are not automated in HP Tuners. And yes, EFILive does cost more.
