Upgrading crank pulley
Yeah, that's why I'm trying to find an alternative. A&A recommended a Summit model (as listed above) but I had a less than pleasant experience with something I bought from them years ago, but if it's my only option over stock then thats what I will have to roll with.
Also as an FYI/warning , I had a miserable experience with Colorado Speed with the IW balancer I can't use. They want a 25% "restocking" fee for a part I didn't use and didn't even take the plastic wrapping off of. Must be nice to make $125 off of a return on a part they list as an in stock part. I'd have a little more understanding if it was a custom order part. Guess thats not how I do business, if I did I wouldn't have many of my customers left.
They hit the bracket
Crap, the IW balancer sticks out too far for the A&A system (6 rib). I don't want to convert to an 8 rib system (just spending $ I'll never use up to it's potential), so this is what A&A recommends.
http://www.summitracing.com/parts/sum-c2501
Is that pulley same size as stock? Or bigger?
I have been through all of this and then some. I almost just switched to the 8 rib but at $1,100 I coudn't afford it with the motor build and all the other crap I did. I ended up just buying a new stock one for $180 because the summit one and the ATI do not fit on the Z06 with A&A kit. I am just going to do the 8 rib and flip drive later when I got some more scratch. I hate it because the motor was out, it would have been so easy.....
I run this one with an A&A kit and 6 rib.
http://www.summitracing.com/parts/pf...model/corvette
It isn't OD, just a better stock diameter option so the factory unit isn't a worry.
It will.
I'm surprised the summit site says it will fit a ZO6 as well. They use a different balancer due to the dry sump and the snout of the crank being different.
#33
^^^ ya don't trust Summit's application guide..lol
The part number I linked is good for wet sump cranks only.
#34
#35
How about the Fluidampr for an LS3 car? I just bought a T-trim A&A kit and I'm glad I saw this thread. I was about to get an Innovators West. That would have sucked.
The Fluidampr is listed as 7.75"
http://www.summitracing.com/parts/flu-760111/overview/
The Professional Products is listed as 7.5", and it doens't say if it fits an LS3 car.
#36
