New build - ProCharger F-1A / 365ci / LSA / E85 [*UPDATE* 915whp/815wtq]
Let me save you some trouble with the spacing of the Procharger Blower Pulley. I just went through this. You'll need their part PDW01C-160 / .160 D-SERIES IMPELLER SHIMS. This was for my D1SC, but the F1A should use the same one.
.160" thick and it spaces the blower pulley forward, using the same bolt.
Here's a pic
Here's a pic
Plenty patient, could be a doctor after (well with patient) Nice job but I don't know if my 2 cents can worth anything, I hope it do, maybe as everything is out now you can upgrade the headers to 2", only because power is an addiction and eventually you will want to get the most out of it, the 2" headers by ARH is what I used after removing my 1 3/4". I just believe its best to do it now while everything is out and while the upgrading spirit is in you and the green is spending. Always remember your used set can sell very fast to help offset the new price.
Here's a pic
Here's a pic
im intersted to see your numbers.. please post up a dyno image when done.. im running the same pully sizes as you and am interested to see how the combo differences does power wise.. i know the smaller cubes will mean you dont run out of steam up top like mysetup is
#33
#34
434 lsx and F1R 4" blower 8" crank pully.. and over 6600ish its plain out of steam.. the motor was built for an F2... the F1r just doenst push enough air up top. its setup very conservitavly.. 4000-6500 it makes good power compared to the same blower on a smaller motor.. but 6500-7000 its very obvious the blower just cant push enough air. i would need an F1X or F2.. and im just tired of ****ing with it.
#35
its already complete..
Assume it broke 1k?
#36
mine made 926/896 with a very safe tune... but the power curve seems pretty good till it runs out of steam.
#37
Not sure what the issues are but most of the serious F1R piloted cars are making 1200 rwhp easily.
I think alot of it has to do with 4" stroke most people run. The Fastest F1R cars are running no more than a 3.4" stroke.
I'm going to an engine building tuning seminar at Steve Morris's this weekend and I'm hoping he can shed some light.
Here's an old school setup with 23 degree heads.
#38
I would like to break 900 on e85, so we will see. I may over spin it with a 3.70 pulley plus meth and see if it makes any more power and if intake temps stay in check.
#39
Overspinning the F1R is not a good idea-ever. It will build a tonne of heat. 74k is the max an F1R should be pullied to, after 68K watch the temps just skyrocket.
Like i said.. i got a killer deal on the motor, but it was built for an F2 ( came out of flying medics 1400 rwhp F2 car) but i just couldnt say no to the deal.
I have alos seen a BUNCH of similar motor setups with the F1r and similar blower pully combo make almost the exact same numbers... so.. there is nothing " Wrong" with the setup.
#40
most of the BIG power F1R cars from what i have seen are smaller motors, and have a big peak.. my blower is hitting around 70k rpm @ 6600 rpm so its not being over spun.
Mine made very similar numbers to yours.. I was using a 4.25" pulley(69k@6800)... I was at 901/820 SAE at 6000 and holds it to 6500...just started to drop past 6500...(only a 226/238 cam)... It was 926/840 uncorrected. 17* on 93 oct/meth.
We figure a larger cam, couple more degrees timing would make 950 ish SAE with the same 4.25" pulley at 6800 or so....this is on 402".
I also think it would be hard pressed to make 1000rwhp with my f1R.. It would have to be set on kill in every category, and pullied down, and a big cam swap...
