HOB F2 Procharger Kit
We are selling a HOB F2 Procharger kit. Pulley setup makes 25-27psi.
Retail on the kit is over 12k
House of Boost LSR Cog Drive (v1):
Retail for everything listed below would be $9,895 shipped, though you can run some of your own options if you want (sprag pulley, balancer, supercharger model and finish, bov, water pump, etc).
We don't include an intercooler setup though. You can run your own water pump setup, but we offer the Edelbrock Mechanical version because it has a slimmer profile than the stock pumps, making it easier to run our belt.
Pics attached!
HOB Cog Brackets
brackets, hardware, cog belt tensioner, cog idler pulley, 4rib/6rib transfer drive, 40mm or 50mm cog belt
= $3,895
ProCharger Supercharger Head Units
= $3,135 F1D, F1, F1A
= $3,435 F1C, F1R
= $4,045 F1X
= $4,315 F2
ProCharger Cog Pulley and Hardware
= $180
Open Race Bypass Valve with Aluminum Mounting Flange
= $385
Edelbrock Mechanical Water Pump
(8896) and pulley (8898) for thicker shaft and slimmer casting
= $400
Power Steering Modifications
Hose and fittings to clear transfer drive components
= $100
Innovator's West Cog Balancer
= $700
We will take 8k OBO for this kit.
Pics attached!
HOB Cog Brackets
= $3,895
= $3,435 F1C, F1R
= $4,045 F1X
= $4,315 F2
= $180
= $385
= $400
= $100
= $700
House of Boost LSR Cog Drive (v2):
Pics attached!
HOB Cog Brackets
= $3,895
= $3,435 F1C, F1R
= $4,045 F1X
= $4,315 F2
= $180
= $385
= $400
= $100
= $700
Pics attached!
HOB Cog Brackets
= $3,895
= $3,435 F1C, F1R
= $4,045 F1X
= $4,315 F2
= $180
= $385
= $400
= $100
= $700
