C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
1,049 whp, what's wrong with this curve?
Old 04-09-2013, 03:41 PM
ALTECH
ALTECH's Avatar
St. Jude Donor '14
Default 1,049 whp, what's wrong with this curve?
Hello everyone,
I am posting these two dyno runs of my 2007 Z, one without meth and one with. I dont't think the drop of power past 6,200rpm is normal. I would like to know if the problem lies in the YSi spinning too fast and going way out of efficiency. I keep reading about over spinning the YSi to 80,000rpms and I am only spinning it to 63,400 at 6,200rpm and 71,000rpm at 7000rpm. I have enough fuel, 1,7/8 headers, stock mufflers.
At 7,000 rpm boost is 25psi
Your comments are appreciated. Thank you very much.
[/IMG]
Old 04-09-2013, 03:57 PM
venomws7
venomws7's Avatar
More info on the setup good numbers.
What springs are you running? I'm surprised the car only picked 9rwhp with the meth
What cam ? compression?
Old 04-09-2013, 04:02 PM
0carlos@redline-motorsports
Former Vendor
carlos@redline-motorsports's Avatar
Air fuel? I only ask because it appears that the meth pull carried a little further. That's about where the stock intakes peak though. A big cam will help it carry a little but not much as it's really dictated by the intake manifold.
Old 04-09-2013, 04:06 PM
ALTECH
ALTECH's Avatar
St. Jude Donor '14
I though about valve float also, I am using Patriot Extreme.
I am just spraying a little meth to lower the IAT about 40degrees, if the meth stop working the engine will not suffer.
CR is 9.7; cam is a big one.
Old 04-09-2013, 04:14 PM
mchicia1
mchicia1's Avatar
What pushrods are you using? If they're 5/16" that might be your issue as they're most definitely flexing.
Old 04-09-2013, 04:15 PM
0Cunningham Motorsports
Former Vendor
Cunningham Motorsports's Avatar
what cam is in it? meaning what lobes ? factory ls7 heads ? what valves in the heads? you run a
.050"-.060" shim under the spring base to get the install height correct? if your running an aggressive ramp rate cam, with a taller ls7 install height, and add in 25 lbs of boost, you're going to run into issues...
Old 04-09-2013, 04:18 PM
ALTECH
ALTECH's Avatar
St. Jude Donor '14
They are custom length CompCam 3/8 with High RPM Lunati lifters
Old 04-09-2013, 04:21 PM
Former Vendor
What pushrods are you using? How big is the cam?
Old 04-09-2013, 04:22 PM
Former Vendor
Got tree'd lol
Old 04-09-2013, 04:23 PM
Former Vendor
Originally Posted by carlos@redline-motorsports
Got tree'd lol
sleeping at the line man!!
Old 04-09-2013, 04:25 PM
ALTECH
ALTECH's Avatar
St. Jude Donor '14
So, you are saying is not the SC.
The cam is a custom from EPS, LS7 heads, no shims. If I install shims, I'm going to have to change the spring, they would collapse.
Former Vendor
Looks like a FAST intake on there if it's the one in the Avatar. 6500 peak is where they peak. Not sure how much more you are trying to get out of it.
Old 04-09-2013, 04:28 PM
Former Vendor
if the boost is still rising up i doubt it... EPS generally is spot on for the camshaft in boosted apps, so i bet the cam lobe is right, why do you have to swap the springs? without a shim your install height is going to roughly be 1.850ish on a stock ls7, if you throw in a .050"-.060" shim you'll be around 1.790-1.8" which is the install height the Patriot Extreme spring is rated for.... not understanding "the spring with collapse" comment..
Old 04-09-2013, 04:29 PM
Former Vendor
yeah i got you, but its not going to look like that, especially with a centri, it will just level out and taper off, not take a nose dive...
ALTECH
ALTECH's Avatar
St. Jude Donor '14
Just want to know the reason for the sudden loss of power.
Old 04-09-2013, 05:09 PM
Former Vendor
what plugs and what gap?
Old 04-09-2013, 05:10 PM
ALTECH
ALTECH's Avatar
St. Jude Donor '14
Because with the lift of the exhaust valve it would be too much for the spring.
To 1,049 whp, what's wrong with this curve?
Old 04-09-2013, 05:12 PM
ALTECH
ALTECH's Avatar
St. Jude Donor '14
TR7ix @ 0.028"
Old 04-09-2013, 05:14 PM
Former Vendor
TR7ix @ 0.028"
You should be in an 8 or a 9 at that power level. I would tighten the gap to 022. Might be blowing out the spark right up there at peak. My spark blows out at 028 by 5800 ish.
Old 04-09-2013, 05:25 PM
White_Lightning
White_Lightning's Avatar
what pullies? i dont see an underspun YSI making 1050 rwhp honestly..
Quick Reply: 1,049 whp, what's wrong with this curve?
