Nitrous Tuning Question
I am going to be installing a nitrous kit on my car. I was curious what people have been doing for tuning. I have a built bottom end, cam, full exhaust, etc... I am going to be doing a 150 shot. Are you guys running something like a diablo and switching between two tunes? are you just running one tune with timing always pulled? I am trying to see what the safest and best solution is. I do daily this car a lot in the summer as well. The nitrous kit is a wet kit with a fogger.
LPE or NX timing controller. When you activate the n2o it can pull timing.
Supporting Vendor
I've used the LPE Two step/Nitrous retard. It works great and easy to setup/change.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Mail Order Tuning & Sales
704-307-4227
www.pcmofnc.com
704-307-4227
I ran a MSD Timing Twister and let it pull timing when the system was armed. Very easy to use and when I upped the shot just adjusted the tune. Make sure you have the correct plugs, fueling, and timing on point.
