F1R to F1X swap : Pump gas numbers
#42
i dont think 1300 is doable on pump/meth.. c16? very likely.. but im not willing to pully it down. so.. if it hits 1200+ on c16 and ! filter i would be ecstatic.
#44
11 degrees of timing? thats freaking low, but i dont know how low is too low. What happens when inlet temps go up on a long pull, how much timing do you end up with?
Anyone wanna chime on this?
#45
Damn man, thats a hell of a jump in power!! Great test btw, blower swap only and same pulley etc etc... Goes to show how much more that F1x flows up top...
Damn near 200hp gain and broader power band at that... That was money well spent...
Did you log your IATs? I'm curious how hard its spinning. I know the F1x has a bigger step up then the R... another reason you gained so much boost..
You'll be tearing some ***** up at the next TI event if you can get it to hook...
Congrats on a great combo..
***Note to self***
F1x on my list of future mods...
***Note to self***
#47
Don't tempt me bastard!
I already have the right bracket, 10 rib and custom HD tensioner... I'd just have to slap the head unit on..
But I'm already seeing 21-23 psi with the F1R... Not sure if I want to push anymore thru it on a 4 bolt LQ9 block..
Gives me room to upgrade down the road tho..
Hell if I got half of the gain that Whitelightening got I'd be happy..
#48
I dont have the logs my Tuner does.. but he knows how finiky i have and he every tune he does to my car is as safe and conservative as he can get.
#51
Oh I didnt know they had the same step up... An F1R is 5.40:1.... I didnt know the X was the same...
So you gained all of your boost from just a better supply/more volume then... Not from spinning it harder.
That was a great investment you made on the X for your big cube motor... On my little 402, I'm not sure how much the X would gain me if I'm already seeing 23 psi with the F1R and don't really want to put too much more boost then that in it...especially on pump gas/meth.
#52
#56
Just for reference on the fuel issue, I had ID1000s and was at 69% duty cycle when I topped out the dyno at 1000rwhp. It was probably around 1050whp but the software needed an update, so it just flat lined at 1000whp. That was 93 and meth (runs about 11.4 AFR on just gasoline, 10.4 on the meth)on 18-19psi. Are you maintaining fuel pressure?
#57
#58
First off I hate u lol Jk, but I'm running those injectors on e85 making 922/855 at about 75% duty cycle give or take
#59
adding some timing and race gas wont increase the requirements for fuel, just octane. Should be good with 127s.
#60
On your comment above, I'm in the same position right now. I'm thinking about adding some race gas and a couple of degrees of timing. I figured if it makes more power, that means more airflow which would require more fuel. I feel like my fuel pump is almost at it's limit currently and that's why I haven't tried yet.
If it can run leaner on the race fuel I may be ok, but if not I guess I'll have to wait until I upgrade the fuel system.
