C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Every Tech should have this LS Timing cover Alignment Tool!
Old 05-30-2013, 02:57 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Every Tech should have this LS Timing cover Alignment Tool!
AlignIt is a LS Timing Cover & Rear Main Cover Alignment Tool and Seal Installer!
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9 Timing and Rear Main cover and seals.
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Timing Cover AlignIt Only $26.95
Rear Main AlignIt Only $37.95
http://www.saccitycorvette.com/Timin...nmenttool.html
Here is a video that shows how simple it is to use.
Installation with Oil Pan off.
Here is a Video the shows installation of Rear Main cover and seal with the Oil Pan on.
AlignIt Rear Main Tool.
Only $37.95
Front & Rear AlignIt Kit. Save 10%
Only $58.41
Hub simulator only $23.95
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 05-30-2013, 06:04 PM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
Ordered one earlier this week, Now make one for the rear cover.
Old 05-30-2013, 06:52 PM
SacCityCorvette
Supporting Vendor
We are working on it!
Old 05-31-2013, 04:01 PM
Z06-TT
Z06-TT's Avatar
just use the flat plate for the rear..... also works on the front.
i think your little thing is great. but i would still want to use a flat plate...... didnt watch the video just saw the little thing that goes over the crank... btw will that work with the front voer pulley seal installed.????
Old 05-31-2013, 04:03 PM
Z06-TT
Z06-TT's Avatar
ok i watched it... maybe make a flate plate that goes from the black to the cover to help get it on flat.
Old 06-01-2013, 10:20 PM
gotjuice?
gotjuice?'s Avatar
St. Jude Donor '13
Most will use this tool with the oil pan installed, So that will take care of the twisting to the front cover.
Old 06-03-2013, 01:06 PM
SacCityCorvette
Supporting Vendor
I see what your saying Z06-TT. But its pretty easy to just use a straight edge or something like that. Also gotjuice has a point.
Old 06-04-2013, 04:51 PM
SacCityCorvette
Supporting Vendor
The AlignIt, aligns the timing cover with the crank in seconds and then makes installing the seal easy!
Old 06-10-2013, 06:31 PM
HyeSpeeder
HyeSpeeder's Avatar
Genius Idea ,, I will order one now ... Thank you
Old 06-11-2013, 06:14 PM
SacCityCorvette
Supporting Vendor
Thank you HyeSpeeder, we appreciate it!
Old 06-19-2013, 02:16 PM
SacCityCorvette
Supporting Vendor
Hi Everyone,
We have the AlignIt Rear Main Seal Tool ready to go! We have a instructional video of it on our website. :Cheers:
Thank you,
Christian
Old 06-25-2013, 06:48 PM
SacCityCorvette
Supporting Vendor
This tool sure makes installation of the covers and seals simple!
Old 06-27-2013, 10:48 PM
gotjuice?
gotjuice?'s Avatar
St. Jude Donor '13
Pm shipped total and paypal address for the rear one. Thanks
Old 06-28-2013, 12:29 AM
SacCityCorvette
Supporting Vendor
Hi gotjuice,
Thank you for your business and you can find the Rear Main AlignIt at this link.
Old 07-12-2013, 01:35 PM
SacCityCorvette
Supporting Vendor
Hi,
We now have the AlignIt Oil Pump Tool available.
Old 07-17-2013, 02:42 PM
SacCityCorvette
Supporting Vendor
We have all the AlignIt Tools in stock if you need one!
Old 07-23-2013, 03:57 AM
SacCityCorvette
Supporting Vendor
Originally Posted by Z06-TT
what is the hub similator for??
Hi,
The hub simulator is used if you are leaving the seal in the
Timing cover. When doing this most people use the hub/harmonic
balancer to line up the cover. The Hub Simulator is easier to work with.
Just a note, because the seal lips flex, its not quite as accurate as the AlignIt timing cover alignment tool.
Christian
Old 07-31-2013, 12:32 PM
SacCityCorvette
Supporting Vendor
ttt
To Every Tech should have this LS Timing cover Alignment Tool!
Quick Reply: Every Tech should have this LS Timing cover Alignment Tool!
