C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
8 rib vs 8 rib flip drive
Old 07-04-2013, 11:30 AM
Slo-Poc
Slo-Poc's Avatar
Default 8 rib vs 8 rib flip drive
Im looking into doing a 8 rib and ditching this 6 rib when the engine gets built. My question is do I need to spend the money on a 8 rib conversion with flip drive stuff or do I just get an all in one 8 rib conversation. Looking at the ati kit.
Ill be on a moderate size pulley for 90% of the time on my d1.
thanks for the input
Old 07-04-2013, 12:17 PM
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
I would do a direct drive or flip drive. Leave the alt and p/s alone. Check with Dallas Performance for there setup. Might also look into there Big Mouth Inlet for the supercharger.
Old 07-04-2013, 12:24 PM
Slo-Poc
Slo-Poc's Avatar
Ya the dallas performance piece is the other one im looking at. Im going to try the intake off of detoxxs car but I have the a&a procharger bracket that looks like the sc sits lower or the procharger kit moves things lower. We will see soon
Old 07-04-2013, 12:30 PM
jon6.0
jon6.0's Avatar
I decided to try the Dallas Performance flip drive with my six rib setup. I will have a 7.5" crank pulley and 3.125" blower pulley with my T-trim. I'm dropping the car off on Monday and it should be retuned by that next Saturday. I'm also doing some Brian Tooley dual springs and pushrods so I can spin it to 6800-7000rpm if I want.
Old 07-04-2013, 12:56 PM
Slo-Poc
Slo-Poc's Avatar
Pm the pricing on the dp kit please. What crank pulley did you do?
White_Lightning
White_Lightning's Avatar
IMO.. if you are already moving off your 6 rib, just go 10 rib direct drive.. that way if you upgrade blowers later you are already 10 rib..
I highly recommend doing a direct drive..
Old 07-04-2013, 01:40 PM
jon6.0
jon6.0's Avatar
I got the direct drive from a buddy demodding his car. Just email Dallas Performance. But if I remember right they are around $750. I agree with the ten rib idea. It's only an extra couple hundred. Colorado Speed has them on sale right now also for $1341.
http://www.coloradospeed.com/innovat...2-p-21251.html
Old 07-04-2013, 01:43 PM
gotjuice?
gotjuice?'s Avatar
St. Jude Donor '13
Maybe a little less.
Old 07-04-2013, 01:55 PM
Slo-Poc
Slo-Poc's Avatar
The d1 is a big blower when you max it out then put a 150shot through it
best of both worlds
Old 07-04-2013, 02:19 PM
White_Lightning
best of both worlds
I prefer to keep it simple.. On power adder at a time.
Old 07-04-2013, 06:57 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
You only need the crank/blower pulleys for 8/10 rib once you do the DD. So don't waste money on the whole kit.
Old 07-05-2013, 09:25 AM
turbotuner20v
turbotuner20v's Avatar
Direct drive for sure, by the time you mess with all the other 8 rib pulleys the cost has to be similar.
Old 07-05-2013, 09:36 AM
Randy@RaginRacin
Supporting Vendor
Randy@RaginRacin's Avatar
Jump to the ten rib set up. with a six rib for the a/c. The 4 rib belt does not hold when it is 90+ outside with a/c under a load. If you have to buy the 8 rib pulleys the 10 rib set up will be very close in price and you will be ready for the next step.
__________________
RAGIN RACIN
Randy Leger
337-278-8397
sales@raginracin.com
http://www.raginracin.com
Old 07-05-2013, 08:28 PM
Slo-Poc
Slo-Poc's Avatar
So does anyone know how much the ati kit is?
Old 07-09-2013, 01:37 PM
croatbob
croatbob's Avatar
can someone explain the dd or fd to me? ive got the 6 rib and will need to upgrade once i forge the engine
Old 07-09-2013, 01:47 PM
turbotuner20v
http://www.cartek.net/HPE/FlipDrive/index.php
Old 07-09-2013, 04:26 PM
croatbob
croatbob's Avatar
Originally Posted by turbotuner20v
ah ok. cheers bro. now its makin sense lol
To 8 rib vs 8 rib flip drive
Old 07-10-2013, 04:13 AM
c6vette142dude
c6vette142dude's Avatar
I went with the Dp DD 8 rib setup. Like with anything, preferences will be all over the place. When I do builds, I look to add quality, durability and reliability, as well as room from growing.
Old 07-10-2013, 09:08 PM
Slo-Poc
Slo-Poc's Avatar
Yes definitely agree. This build will be the cars final resting place and will see plenty of beatings.
Old 07-10-2013, 10:20 PM
Detoxx03
Detoxx03's Avatar
Lets say he does the 8 rib kit without the direct drive is it as simple as adding the direct drive later if he wants or will he need some other knick knack things?
Quick Reply: 8 rib vs 8 rib flip drive
