C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Which 6 bolt heads?
Old 07-24-2013, 01:01 PM
croatbob
croatbob's Avatar
Originally Posted by Z06-TT
Any one try the new RHS ls7 6 bolt???
my thoughts exactly. same mob that makes the rhs blocks?
Old 07-24-2013, 01:16 PM
breecher_7
breecher_7's Avatar
I have a set of the RHS LS7 units in my machining center right now...
I still like the MAST ones better.
Old 07-24-2013, 01:27 PM
croatbob
croatbob's Avatar
damn by the time u add ti valves on the mast 305s u get no change out of 5k. can they really be that much better than prc and rhs at 3k?
http://www.racingheadservice.com/rhs...501-06tts.html
if there heads are anything like there blocks they should be pretty good
Old 07-24-2013, 01:38 PM
newschool
newschool's Avatar
I wouldn't let PRC port a stock casting for me let alone provide me with one of their castings.You ever wonder why no engine builder uses them??
Old 07-24-2013, 01:39 PM
croatbob
croatbob's Avatar
i assume they are still of good quality tho? mast 5k. rhs 3k. we arent talkin chump change difference.
Old 07-24-2013, 01:40 PM
croatbob
croatbob's Avatar
yeah most builders have told me similar. the rhs mite be a good alternative for the prc
Old 07-24-2013, 01:41 PM
newschool
newschool's Avatar
From what i have seen the RHS casting has little improvements aside from the extra bolts over a stock casting. I had a set of world castings on my tall deck motor and they had all kinds of stupid going on with them.
Old 07-24-2013, 02:40 PM
croatbob
croatbob's Avatar
ah crap! price is per head not a pair the way im reading it. (rhs) mast 305 cheaper n betta option then
Old 07-24-2013, 04:30 PM
nareg
nareg's Avatar
What about the new trick flow heads? They're approximately $2500 a set.
Old 07-24-2013, 05:02 PM
croatbob
croatbob's Avatar
245cc?
Old 07-24-2013, 06:20 PM
nareg
nareg's Avatar
I believe it's 255cc. From what I read it works with LS3 and LS7. I'm on the fence of getting those for my car but it would be nice to get some feedback from someone using them on a FI LS3 or LS7 1st.
Old 07-24-2013, 06:27 PM
croatbob
croatbob's Avatar
245cc. Uwilluz uses em on his tt z06 that makes 1000+. Currently selling his ride on this forum
Old 07-24-2013, 06:37 PM
  #33
croatbob
croatbob's Avatar
Does the factory rocker gear bolt up to the mast heads? Fitting is purely remove the old heads n fit the new ones or addition things need to be purchased besides gaskets n fluids etc
Old 07-24-2013, 07:30 PM
  #34
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
TFS head is ls3 style port so would need a different intake manifold/rockers/pushrods/etc.
Old 07-24-2013, 07:39 PM
  #35
croatbob
croatbob's Avatar
trick flow? yeah not goin that way. wanna kno if the stock rockers will fit the mast 305s as the manifold etc will
Old 07-24-2013, 10:08 PM
  #36
playtoy
playtoy's Avatar
Yes they will. Stock Bolted right up to mine
Old 07-25-2013, 08:21 AM
  #37
ZO6er
ZO6er's Avatar
Black Label FTW!!
To Which 6 bolt heads?
Old 07-25-2013, 08:57 AM
  #38
croatbob
croatbob's Avatar
Originally Posted by ZO6er
Black Label FTW!!
Trying to decipher your comment? Lol
Old 07-25-2013, 09:31 AM
  #39
Unreal
Unreal's Avatar
Mast is Black Label. That is their name for their products. FTW is for the win, LOL is laugh out loud FWIW.
Old 07-25-2013, 08:06 PM
  #40
croatbob
croatbob's Avatar
ok guys last question before i order. which upgrade do you guys suggest?
Rocker Stands? no need due to stock rockers correct?
Inconel Exhaust Valves....not much more than stainless so why not or light weight stainless be more than enough?
Flat Mill Decks???
TL-RET10: Tool Steel/titanium Retainers?? steel retainers be fine or should i go titanium?
cheers lads
Quick Reply: Which 6 bolt heads?
