DashLogic alerts could save your engine
Former Vendor
I am sure DashLogic will work, I can't be sure about the Aeroforce. We structure our messages so we know only the response to our messages. If they have a similar system in place, it should work.
Former Vendor
Just checked these out at the show. Very cool product and I would have bought one impulsively if there had been any kind of show special. Most vendors have one.
Since it was full retail I will just order one if I decide to, but when I think it over, I really don't need it.
Former Vendor
Former Vendor
On sale until the end of the year!! Get $40 off
http://www.palmerperformance.com/sto...x.php?cPath=32
Former Vendor
I have a question regarding the DIC.
I don't have the HUD on my vette. With the dash logic, I only get one screen to put what ever data points I want to monitor?
Or can I add more than one? For example - first DIC page monitors Boost and Fp, then scroll to the next one for IAT and Knock?
It's a great little device. Lots of available data to scroll through. It's not a substitute for data logging, but it's really nice to be able to keep tabs on so many different things so easily.
You'll want to pick up a ZR1 MAP sensor if you want the monitor boost. At least that's the best and easiest way if you ask me.
#35
Dash logic doesn't generate any data so not sure what you would log from it. If you want to log data get an obd2 logger or any 0-5V logger.
#37
Grr. Wish I saw this before. Just plugged in expecting it to read boost from my ls2 MAP. Read gibberish. Better install that ZR1 MAP thats been sitting on the bench for months. Is there a trick to get their software to work with a Windows8 machine?
#38
As for the windows operating system, I don't have a clue. Sorry.
#39
Technically you don't have to mess with tune if you wanted. Could just wire the zr1 map in, and run the output to the input on the dashlogic and then setup the dashlogic software to read boost. No messing with tune or HP tuners. Can use any map sensors and just run the output to one of the dash logic inputs. Read it direct instead of through the ecu. Only need to use HP tuners to setup the map to read through the ECU.
#40
Former Vendor
New Firmware available. This firmware has added a PID so you can set an alarm to washer fluid level (for methanol injection cars), added MAF Hz, and Vehicle voltage.
http://www.palmerperformance.com/dow...ware_v1.17.ehx
We have also added several vehicles to our DashLogic lineup, now available
2010-2014 Camaro
2007-2013 GM Truck and SUV (gas and diesel)
2005-2010 Cobalt
2010-2014 Cruze
2010-2014 Camaro
2005-2010 Cobalt
2010-2014 Cruze
