C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Forced Induction engine reliability list
Old 10-29-2013, 10:37 AM
ZoLOW
ZoLOW's Avatar
Have a car we can add (stock bottom end)
ZoLOW / SUPERCHARGED (A&A T-TRIM) / 8lbs. / 635 / 540 / LS3 / 25K / 31.5K / NA / 91 / M6
It is my DD at the moment picking up another vehicle this winter or spring (good thing about TX can pretty much drive my vette year around without any weather issues) so it sees plenty of street use and take it out to play on the weekends when we have something going with our local group
Old 10-29-2013, 10:44 AM
Detoxx03
Detoxx03's Avatar
Originally Posted by Devilish34
The biggest question on longevity is how hard do you run your car?? 600-700-800whp could last for years depending on how you use it..
When I drive mine I give it hell. Without going into detail it's see's a lot of rpm and often.
Kraigmont (03-16-2024)
Old 10-29-2013, 11:23 AM
jon6.0
jon6.0's Avatar
Exactly how I drive mine. I see 6700-6800 rpm in 3rd and 4th daily.
Old 10-29-2013, 11:26 AM
jon6.0
jon6.0's Avatar
A&A T-trim / 12psi / 719rwhp / 618rwtq / stock LS3 with cam / 24k / 28k / N/A / E85 + Meth 15* timing / M6
Old 10-29-2013, 11:29 AM
jon6.0
jon6.0's Avatar
I think we should also put how much timing we are running. My tune is very conservative at 15* of timing on E85 + meth with 12psi. I'm at 719/618 like that. Some folks are running 18-20* of timing with that much boost and getting high 700's on rwhp. I may get a different tuner to tune my car.
Old 10-29-2013, 11:36 AM
Le Mans Z06
Le Mans Z06's Avatar
I can add that if others can update their info. Unfortunately I don't know mine
Old 10-29-2013, 12:07 PM
jon6.0
jon6.0's Avatar
Originally Posted by Z06-TT
so for im the highest SBE. ( very small head changes ) and running turbos....
i really think you all would have higher numbers if the supercharger wasnt belt driven.
I get asked all the time if I have a turbo. I always say "yes, a belt driven one".
Old 10-29-2013, 12:11 PM
Devilish34
Devilish34's Avatar
I like low ET over high dyno numbers.... Thats where everything comes together
Old 10-29-2013, 01:13 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
I run 20 * at 12 lbs, but wouldn't do that on a stock shortblock.
Old 10-29-2013, 01:25 PM
kedar
kedar's Avatar
St. Jude Donor '12
How about details on drivetrain modifications? ECS trans brace? Clutch? Upgraded transmission, differential, axles?
Old 10-29-2013, 01:30 PM
Devilish34
Devilish34's Avatar
Francis you may want to put this on a spread sheet and load as an attachment
Old 10-29-2013, 01:33 PM
fonzo
fonzo's Avatar
would it be too much to add a list for those that are running Nitrous as their power adder? I am running nitrous for now, but information for nitrous seems to be pretty limited for those of us that run nitrous.
I will be going supercharged eventually, so this info is very cool for me!
Old 10-29-2013, 01:53 PM
  #33
Le Mans Z06
I already asked an admin to change the thread title, and in the initial post edited it for forced induction vs boost. Give me your info and I'll add it.
Old 10-29-2013, 01:55 PM
  #34
fonzo
fonzo's Avatar
Cool, I have no info to add just yet, I'm still waiting on a nitrous tune and a switch to e85 tune, then I will be able to post my results!
Old 10-29-2013, 06:39 PM
  #35
Slo-Poc
Slo-Poc's Avatar
Any other internal mods with the ZR1 cam? Retainers, springs etc?
Double spring and titanium retainers, and has seen around 15 10lb bottles through it. I think it likes it
Old 10-29-2013, 07:04 PM
  #36
fonzo
fonzo's Avatar
Did you ever run the car with just the zr1 cam before the supercharger? If so, how much did it make n/a and on spray with that setup? I'm wanting to do the zr1 cam and spray it for now until I go supercharged.
Old 10-29-2013, 08:04 PM
  #37
Detoxx03
Detoxx03's Avatar
He didn't have the cam until after the blower. Just a get blower cam from the get go.
To Forced Induction engine reliability list
Old 10-29-2013, 08:45 PM
  #38
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I had
LS7 stock bottom end, A&A kit si trim, cam, heads made 705rwhp on 5.8psi
Lost a cam/lifter which wasn't tune/boost related.
Swapped in a livernois LSX427, ECS Ysi kit, etc etc
Made low 900s on 12psi on a slipping belt, Haven't dynoed it yet since I fixed that and a ton of other issues. ~5k miles on this setup no issues besides dumb little things not related to motor/boost.
Old 10-29-2013, 10:12 PM
  #39
inspector12
inspector12's Avatar
Inspector12/ TTZO6/20-22lbs/1089rwhp/1063rwtq/motor was used from my other car had around 6-7K on it and about 5000miles in the vette/No failers yet lol!/93+meth/Sleeved LS2 block 427CI Brodix heads/16 degrees of timing.
Old 10-29-2013, 10:27 PM
  #40
D&C vette
D&C vette's Avatar
THoR
ECS SL1500 supercharger kit
8PSI of boost
610RWHP / 589RWTQ
LS2
74878 Miles on the car at install
81784 Miles on the car now
93 pump
M6
Comp Cam 232/228 114LSA , LG 1 7/8 headers, hi flow cats, B&B fusion, Monster stage 3 clutch, KB bap (meth installed - tune coming soon)
Street use mainly, little autocross car. Will be hitting strip soon.
Quick Reply: Forced Induction engine reliability list
