C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
re: Fuel rail power support
Old 12-11-2013, 11:04 PM
c6vette142dude
c6vette142dude's Avatar
Default re: Fuel rail power support
Any suggestions on upgrading my fuel rails to something that will support 1000 crank hp?
Thanks!
Old 12-12-2013, 05:51 AM
turbotuner20v
turbotuner20v's Avatar
I make 930 whp on e85 using the stock ls3 rails.
Old 12-12-2013, 02:32 PM
c6vette142dude
Damn! I'm still reluctant to run e85 until there is more infrastructure built up to support e85. I guess the ls3 fuel rails are that much better, but also I had the stock ls2 motor stroked to a .408. That, along with the T-trim is just way too much for the stock fuel rails.
Old 12-12-2013, 05:34 PM
ATLS2
ATLS2's Avatar
how much can the stock LS2 fuel rails handle?
Old 12-12-2013, 06:15 PM
c6vette142dude
Not sure, but at 730 rwhp the car had to be drastically detuned and it's still popping the spark plug on the #7 cylinder. When I was at 611 whp on the stock ls2 block w/V-3 blower, I had no issues whatsoever with the stock rails.
Old 12-12-2013, 07:17 PM
ATLS2
ATLS2's Avatar
dang it. What can I do to fix that? That's exactly the amount of power I'm trying to get. What companies sell reliable fuel rails? Ones that don't catch fire lol
Old 12-12-2013, 09:46 PM
turbotuner20v
I didn't think the ls2/3 rails were that different. ls1 is smaller. are you sure it wasn't a fuel pump issue?
I'm running a return system with the regulator about 18" off the Schrader valve, so that may make a difference.
Old 12-12-2013, 10:15 PM
c6vette142dude
I was using the stock fuel rails w/BAP... what kind of fuel system you running?
I'm glad you brought that up, it's probably just my fuel setup. I currently have 1 400lph intank pump but it's only good to 600hp, but I just installed the T-trim which is needing a lot more fuel. I'm planning to add another 400lph which will support 1200hp in total. Think I will add the other pump first before upgrading the fuel rails. No need to spend the money if I don't have to.
Old 12-13-2013, 01:00 AM
greerracing
greerracing's Avatar
I was making over 800ftlbs of torque with stock ls2 rails id1000s and a upp fuel system. You're running out of fuel or your tunes not right but if you just have a BAP I'd venture to guess your out of fuel pump.
To re: Fuel rail power support
Quick Reply: re: Fuel rail power support
