800 + rwhp stock LS3 short block with F1A
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Pushing a stock LS3 short block on pump gas and a big cam.
Specs before the blower install
Before blower numbers vs how it first arrived to us. (517 rwhp)
The above graph was how the car arrived to us about a year ago vs the install of the FAST 102 combo, G6X3 cam, LG ported LS3 heads, and full LG Super Pro exhaust. As you can see it would a stout NA build from the get go, and all components were left un-touched before the blower install.
Procharger front mount 3 core intercooler
F1A Head unit going on
Race by-pass valve
F1A kit finished.
Alky Controls Methanol kit going in
The car is still running on 93 pump gas with the same heads and cam...for those of you that don't think you can force a G6X3 :biggrin:
- LG Super Pro Long Tubes and exhaust
- LG G5 Velocity CAI
- LG G6X3 cam kit
- LG ported LS3 heads (11.4:1 compression)
- FAST 102 intake
- NW 102 TB
- ASP underdrive
- Centerforce DYAD clutch
- DSS shaft and axles
- Weld RTS 17" wheels
- 93 pump gas
Race by-pass valve
F1A kit finished.
Nice! I'm about to swap my Pfadt headers for LG Super Pro 1 7/8 and put a 2.87 pulley on my T-trim. Should be close to or just over 800rwhp. At least I'm not the only crazy bastard pushing a stock LS3 hard.
I hope that she holds up for you.
Former Vendor
Just becareful on the tune...and keep in mind at this power level that LS3 isn't going to go 100,000 miles. It's been running like this for some time though. Customer is fully aware of what all is involved in this setup and risks associated with it.
Wow.
Should I use any copper gasket spray on the slip fit joints of your headers?
Former Vendor
This car had approx 25k miles when we started the entire build. Another 5-6k miles on the heads/cam/intake and we are going on a couple thousand with boost now.
