Slo-poc, Futral Motorsports Build
#41
I did get a 1.50 out of them, which was much better than my MT's and a good 60 for our track. Next run broke a hardened shaft in my diff, and the one after that an axle. Rough season but hoping no more breakage this year.
#44
The country roads around my house are kind of rough and chew up tires, but they work good for getting traction when you're screwing around.
I like Hoosier DR's for the track. Consistent 1.4-1.5 with my old GTO. Very flexy sidewalls.
#45
Trick flow heads are on the way and the block has been all cleaned and all that goodness. Assembly will start next week and will have pictures of the process as soon as detoxx or I make it over that way. I know he has a little something something going on/in
#46
Yep my car has a hot date over there.
#48
Ouch..... Sorry to read about all these things breaking.
#49
looks like you are going to have a killer build.
#50
cool! i love new builds
#52
Detoxx went by there this morning. Motor will be getting put together and put in the car asap. Still waiting on a few parts so looks like its going to be done close to march
#53
Got these today, resembled my ccws and will probably get powder coated also after tx. 17x11
Only one problem, opened the Box and saw one has a Hugh dent from lip to drum. Spun it on the machine and the whole wheel is bent. No damage at all to the box. Called weld ASAP and they should get back with me in the morning about how long before they can make a new one.
#60
13 mp of shake
