Supercharger dip stick, Uh Oh! HELP
It has happened. I have rounded out the hex head on my Paxton SC head unit. Has anyone else been down this road? I tried the next size up allen key, no luck, went up one more, no luck. Any ideas????
Can't really see striping one like this but just use an easy out to remove it then order a new dip stick or plug whichever one went bad!
Get an EZ Out, those brass plug heads are soft. You really have to be careful how tight you crank them down, I put mine back just slightly better than finger tight after almost stripping it out the last time.
I got the dip stick out. Due to the angle I did not attempt to cut across the head but instead cut a slot in the side vertically. The vertical slot allowed me to use a small flat blade screwdriver and rubber mallet an lightly tap until the dip stick broke loose.
St. Jude Donor '13
Sometimes rounded off allens you can go ahead and grab a torx bit of similar size (Little tap from a hammer) and grab on it. You will most likely ruin most of the socket head too when you do this. I have had to do this when we get in Procharger's with the allen bolts that people think need to be 150 ft.lbs because it holds a bracket onto the head unit
