C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
17x9.5 54mm offset work on base?
Old 09-14-2014, 09:30 PM
  #41
No Juice
No Juice's Avatar
So both of you are running the C6 Z06 front 17x9.5 54mm wheel ? and 5 Liter is using the deep dish version ?
5 liter - I believe the WS6 wheels are 17x9 50mm offset
Old 09-14-2014, 09:58 PM
  #42
narfdanarf
narfdanarf's Avatar
I just ordered base c6 5 spoke replicas in 17x9.5 +54mm wheel, but I decided to use the M&H 275/50r17 drag radials instead to get a little more side clearance since the wheels have an aggressive offset.
Old 09-14-2014, 11:07 PM
  #43
ATLS2
ATLS2's Avatar
Yes, 17x9.5 54mm offset. I have z51 rear brakes and stock height.
Old 09-15-2014, 08:25 AM
  #44
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
Ours are 17x9.5 54 replicas from OE Wheels. I'm not positive that the OEM Z Wheel is the exact same size/offset.
And you're right about the WS6 wheels, I saw that when I took them off, I had the specs on those totally wrong. These fit much better.
Old 02-06-2015, 05:14 PM
  #45
villainous_intent
villainous_intent's Avatar
What size rim are you guy running upfront with this combo? I want to finally have matching wheels again, but every corvette rim I find in 17x9.5, I only find a 18x9.5 vs a 8.5 to match. I'm a narrow butt C6 so I have narrow front fenders and I thought a 9.5 for the front would stick out? Also, and word on how these hook? I really need some traction on the street. Thanks for any info you can share!
Old 02-06-2015, 11:30 PM
  #46
narfdanarf
narfdanarf's Avatar
I run the stock fronts and the 17 replica rears. My car hooks all 700whp even in first gear on the street. Haven't turned it up yet, but I think they should do pretty well once I crank it.
Old 02-07-2015, 12:06 AM
  #47
5 Liter Eater
St. Jude Donor '11
Looks good. I guess M&H has a 295/45 too?
Oh, and we're not doing cover sheets on the TPS reports OR coil covers anymore. I'll get you another copy of that memo.
Old 02-07-2015, 12:51 PM
  #48
villainous_intent
Your car looks great! I'm hoping this setup will hold my beast to the road (850hp here).
Sadly I have to buy front rims also if I want a matching set since mine cam stock with the 08 split fork rims, and I can't find them in 17's anywhere.
I tried a 305x35 on an 18x11, but that didn't really hook up at all.
Old 02-07-2015, 11:14 PM
  #49
narfdanarf
narfdanarf's Avatar
I am running their 275/50's. I don't think the 295 MT's would fit without me raising the car and I didn't really feel like doing that, plus I personally feel like the M&H compound is better for a stick car.
The problem IMO with the 305/35's is that they are only 26.x" tall..the 28" tall tires hook way way better.
As for coil covers...they look a lot better than the stock coils and valve covers haha and I'm a cheapass soo...coil covers it is
Old 02-08-2015, 12:08 AM
  #50
villainous_intent
With the 28" tire did you adjust you front tire size any? Do you get any of these "drag warning" CEL's I've heard about? Sorry for all the questions, thanks for taking the time to answer! If you're ever in SC I owe ya a beer.. or 7
Old 02-08-2015, 07:57 PM
  #51
narfdanarf
narfdanarf's Avatar
No but I have had the ABS kick in a few times during braking and I'm assuming that's why.
Old 03-01-2016, 06:45 PM
  #52
NASTYLS2
1st Gear
NASTYLS2's Avatar
Originally Posted by ATLS2
Do you have any problems with rubbing or anything?
Old 03-02-2016, 02:13 AM
  #53
ATLS2
ATLS2's Avatar
None at all. It truly fits perfect
Old 03-02-2016, 09:21 AM
  #54
5 Liter Eater
St. Jude Donor '11
Pretty much that.
Old 05-21-2016, 11:42 AM
  #55
Murdered07
Murdered07's Avatar
I got the drag warning a couple weeks back. you know, the one where are those tires are too far apart as far as height goes. I'm probably going to get a half inch taller front tire to make that go away. I actually need a half inch front raise because o
f the dropped radiator
So this does mess with the car a bit, what about abs or did it go into low power mode or anything odd?
Old 05-21-2016, 12:17 PM
  #56
ATLS2
ATLS2's Avatar
Not at all. I don't know what happens after 135 mph, as that as fast as I take it.
Old 05-23-2016, 09:26 AM
  #57
5 Liter Eater
St. Jude Donor '11
I can verify no ABS or TC errors up to 167.
Old 02-20-2017, 07:48 PM
  #58
da6speed
da6speed's Avatar
Looking for anybody that has tried this with the new 305/45R17 MT Et Street R? From pics in thread, looks like the 17x9.5 w/56mm offset with the old 295/45r17 MT would almost tuck.. Just wondering how much wider the new 305 is...
Quick Reply: 17x9.5 54mm offset work on base?
