C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Spec out a nasty max effort nitrous cam:
Old 04-28-2014, 08:58 PM
Turbo2L
Turbo2L's Avatar
Default Spec out a nasty max effort nitrous cam:
What kind of cam are you guys spraying 225-275 shots running? I'm willing to give up a little bit of drivability to get in the bottom 9s.
Car will have a forged 427, WCCH Stage II heads, NW/102, and 1 7/8" Kooks. Still weighing out clutch options.
Will have a set of Weld RTS on the car for track events. Unsure on the rubber at this time, but open to suggestion in 17" trim.
Old 04-28-2014, 09:02 PM
ProEFI
Supremacy 1 car at a time
Support Corvetteforum!
ProEFI's Avatar
I had that cam on my friend LS3 427, and it's doing great with nitrous dual stages, 200 - 200.
vengeance racing custom camshaft 255/259 624/624 114 LSA
Old 04-28-2014, 09:04 PM
Turbo2L
Turbo2L's Avatar
How'd it do off the juice on the dyno?
Old 04-28-2014, 09:29 PM
lane_change
lane_change's Avatar
248/262 .651/.631 111 LSA is what I am running on my nitrous RHS 447
For tires, I went with the 335/35R17 Hoosier DR's on the 17x11 Weld RTS
Mast 305 heads
Wilson sheet metal intake
ARH 2" headers
Spec carbon twin clutch
ProEFI EMS
ID1000 injectors
Fore triple AEM 320 pumps for E85
Should have her all buttoned up here in a few weeks and then I'll get her dialed in. Old setup made 617/575 n/a on the RHS 447. Shooting for around 650+ n/a this time around and will be spraying a 200 for now on the plate and then adding a 200 direct port on top later on.
Old 04-29-2014, 05:42 AM
Blackonblacksls
Blackonblacksls's Avatar
I had a cam grinded through bullet for my ls7. When I had a 429 ls7 motor in my camaro.
They decided on a 255/264
Old 04-29-2014, 05:57 AM
ProEFI
ProEFI's Avatar
Dyno results
539 rwhp
521 torque
1st stage (low pressure bottle) air/fuel ratio when spraying : rich
722 rwhp
781 torque
2nd stage (low pressure bottle) air/fuel ratio when spraying : rich
994 rwhp
1041 torque
To Spec out a nasty max effort nitrous cam:
Quick Reply: Spec out a nasty max effort nitrous cam:
