Billet Ysi
#81
It is a pain in the butt. Got to go grind more control arm tonight.
#82
#83
Mine was just a normal old school one and still has more left. I find it interesting how people are so interested in this yet almost no one is maxing out the older one. Still haven't seen any results, and no interest in the new one right now because I already make too much power.
#85
Just a wheel swap. You use the same housing and everything. Externally you would never know the difference.
#86
#88
#89
From what I'm told, no and they may not be offered at all. Testing did not go well. The normal wheel out performed them.
#90
#91
2000 vs a billet ysi? Ysi has been out for 10+ years. Gear box is the same, which is what causes the noise, so not sure what you wanted to see.
#92
I have been following this but figured there would be a lot of testing before they actually go in production mode. Vortech just want to make sure you gets your $ worth...
#93
I believe this is an F1X car, first trip out, soft passes... They are changing the setup right now and gonna have spray on top of the X.. Looking for 7s.
8 Second Supercharged Corvette - YouTube
***edit***
This car may have had a YSI in the vid but it has an X now I believe.
***edit***
#94
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,081 Likes
We just received the first 2200R with the billet wheel late last week. We should be testing late this week into next.
Just from looking at it, I cant see it not making more power frankly. Time will tell though.
#95
Hopefully it does well. I had a few PMs from people saying the results were not good at all. These are people I trust so hopefully it was just those combos or something.
Either way, I'm not interested in it. My car makes too much power as is.
#97
Ahahaha. I did put a smaller belt on my Ysi and my tensioner broke. The hole for the wrench, bottom piece just snapped out so now I can't use a wrench to open the tensioner. Ohh well, only an issue if I need to put a new belt on. Got a 54" ten rib on and it is tight as hell.
#98
#100
Any updates DOUG@ECS? My setup has been a little slow going as far as break in on motor. I wouldn't have anything to compare to anyways since I never ran the ysi with the non billet impeller. I also did not receive my stock impeller back from vortech when billet one was installed.? ! It was a brand new head unit, never ran, when I sent it to them.
