Anyone boosting 4.8 or 5.3 in a C6
#41
you might try some alum ducting to better seal off the rad and if possible divert in more flow
I'm using the dewitts/spal fans instead of the stock fans and it solved my airflow/cooling problem
I just have it on a switch with a separate sensor so I can control the on off points with an easy ****
simple and effective
