Motec M150 to Vette with factory BCM?
#281
St. Jude Donor '13
Didn't realise that's what you guys had done on that car. Can you stick some pics up maybe on the other thread? Did you run any pipework through the frame or just seal the rail up? It's quite a large volume compare to say a 5inch pipe. Really interesting stuff though.
No pipe work, all frame, besides the two vband flanges for the discharge entrance from turbos & frame rail discharge (Ya weird saying that) to intercooler up front.
#283
Normally do the same as well after springs installed but not yet on this valve because unproper fitment is so obvious.
#286
Tuomas, I'm a little disappointed in you to be honest! I thought you would have got the guys over at koenigsegg to build you a set of 4 valve per cylinder heads with their pneumatic valve actuators! Lol
Someone really needs to develop a set of heads using these for the LS!
#288
#290
Took one week holiday trip to North Italy and at same drove yesterday to Austria see one friend and his Vette specialized speed shop.
Wanted to see TIKT carbon frond end personally before place an order. Really nice pieces and absolutely best quality I've seen so far.
I'm sold, and gets possibility add two big coolers to front.
#292
That is a nice looking kit. One day when I hit the lotto.
#293
Or why dose someone in the US not just create their own? It's only plastic at the end of the day. Not that hard to do. Even the carbon work isn't impossible. Just takes a little longer.
I'm supposed there aren't more front ends out for the corvette from the US. It could solve so many issue, like cooling.
#296
#297
Received 1,193 Likes
St. Jude Donor '15
Tooling ain't cheap.
#299
Correct! You can make them yourself with a little practice! A accountant in the UK has re-made the WHOLE body of his noble m12 in carbon! This includes the tub that is maasive and complex. He had no skills before but with practice anyone can do it.
You don't need to a big company to sell you a bumper! cut up a stock unit to how you want it. Take some moles and make a copy in carbon. Save about 50% of the weight and make it as strong as you like (all in the layup).
This is what tkit did. Once someone has the moulds then others could even rent them and provide their own materials. Gives the guy the made the moulds some cash back, spreads the knowledge around a little and more people get a cool body panel in carbon that they did themselves. Really surprised there are so few people doing this in the US.
Some don't even do the moulds! They just make the body panels look how they want and then do the layout right on top. Even easier than above but your panels will be the thickness of the layup thicker than the mould bodywork.
#300
Any updates OP on the car?
Also was having a look at Speedhunters and found this car. Reminds me of your car for some reason.
http://www.speedhunters.com/2015/08/...o-4-rotor-rx7/
Think you should do a rear mounted radiator and a MASSIVE intercooler!
