Motec M150 to Vette with factory BCM?
#301
Any updates OP on the car?
Also was having a look at Speedhunters and found this car. Reminds me of your car for some reason.
http://www.speedhunters.com/2015/08/...o-4-rotor-rx7/
Think you should do a rear mounted radiator and a MASSIVE intercooler!
Placed an order of Precision Metalcraft sheet metal intake, looks oem can handle 1 k hp nicely until differences in cylinders goes over 10-12% at boost. We'll continue tuning work after large plenum intake will arrive, hopefully next week.
As well cannot hold back pressure under boost at 10 psi and over, so send email to PTE if they can upgrade turbos to 6870's. Probably will test first with modded DKT housings but looks I have enough clearance convert them to T4 if necessary.
#302
I've been eyeballing the PMC intakes. Put one on a camaro and it was very nice. I know Whitelightning runs one on his 1450rwhp car. Seems like the best intake for the price.
#303
And top notch customer service plus fabbing schedule!! Sent message, few hours later taken care what I need and next day ready to optional anodizing.
#304
Arctic Vette (09-18-2015)
#305
Received 1,194 Likes
St. Jude Donor '15
That is beautiful!
#306
Second dyno session is done, problems solved and car tuned at 1bar/ 14.5psi. Made 1095 hp DIN crank, torq 1333 nm/ 983 lb ft. We pushed boost up to 1.8 bar/ around 26 psi very safe (rich) afr and timing around 10 deg just for test confirm injector and ignition problems really fixed made around 15 k and 13.5 k lb ft torq. At same noticed leak on pressure side need to fix. Fu*king Chinese made copy Wiggins... Now again under work making new bigger down pipes with 4" cut outs, Precision Sheet Metal intake, fenders, hood etc. Finishing before final dyno this year and street testing.
We'll probably make Motec system to work for any C6 boosted or n/a application without factory ECM conjuction OEM BCM and factory electricity. Required custom made M150 and this takes time..
#308
Thanks!! E85, back pressure is still bit over the boost, probably pressure leak is part reason for that. Anyway it must get under the boost secure engine at long WOT mile pulls as well on the street. Will make everything possible first with DKT housings get it low. Probably we'll set max boost to 30 psi if all goes well.
#309
#310
#314
St. Jude Donor '15
Dude, you are nuts.
Beautiful work though
#319
