C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Magnuson blower/fuel question
Old 06-24-2014, 08:53 PM
spaulsen
spaulsen's Avatar
Default Magnuson blower/fuel question
I have recently bought a Magnuson MP112 and was talking to my tuner about getting me dialed in. My car is a 2007 C6 LS2 6 speed. He asked if i was installing a boost a pump or a larger pump to accomidate the blower. I was told i didnt need it but he is afraid Ill be on the edge of my stock pump ability. My car is 100% stock BTW.
My questions are, what has anyone with the Maggie done with their fuel pumps? Another question, can I change out the pump to a ZR1 pump or another like the ZL1 pump? Any help is much appreciated. Thanks, Shawn
Old 06-24-2014, 09:37 PM
Streetk14
Streetk14's Avatar
Those kits originally did include a fuel pump booster (aka BAP). I'd either buy a Kenne Bell BAP with a Racetronix harness, or install a stock C6 Z06 fuel pump. The Z06 pump is a drop-in solution and is what comes with the 600 hp E-Force kit. I have a KB BAP w/ Racetronix harness on my current car.
Old 06-24-2014, 09:40 PM
BLWN427
Support Corvetteforum!
BLWN427's Avatar
I ran my stock Z06 pump and a boost-a-pump that came with my tvs2300 for a year without any issues.
Then I built the motor and pushed the 2300 to it's limits and had to upgrade my fuel system.
Stay the heck away from the eliminator in tank stealth kit. I had nothing but problems out of mine.
Old 06-24-2014, 09:49 PM
spaulsen
spaulsen's Avatar
Is there a vendor here that sells the BAP with the harness?
Old 06-24-2014, 10:33 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Racetronix sells the harness.
Old 06-24-2014, 10:55 PM
spaulsen
spaulsen's Avatar
I actually just found that. Does anyone sell the BAP with the harness?
Old 06-25-2014, 07:53 AM
spaulsen
spaulsen's Avatar
Morning bump
Old 06-25-2014, 08:35 AM
old motorhead
old motorhead's Avatar
Received 1,339 Likes on 947 Posts
Why is it necessary to buy both pieces from the same place? Buy the harness from Racetronix and then find the best deal on the BAP.
Old 06-25-2014, 09:15 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
When you order the harness make sure you order the extra connector for the BAP.
Old 06-25-2014, 01:49 PM
spaulsen
spaulsen's Avatar
If one company sells both wouldn't it be a little easier to get it from them than two different places? Also getting from one place I would think there would be no way to get a wrong part, and get everything youneed the first time. Thx for the info tho.........
Old 06-25-2014, 01:50 PM
spaulsen
spaulsen's Avatar
Thx for the heads up.
Old 06-25-2014, 02:46 PM
m_LeDez
m_LeDez's Avatar
Location: Houston, Tx.....'05 Corvette M6 LS3 Magnuson Heartbeat
......"My questions are, what has anyone with the Maggie done with their fuel pumps?".......
Shawn,
Prior to my new Magnuson Heartbeat I ran a LS2 112 Magnuson for 6-7 years with "ZERO" fuel issues using the kit provided Magnavolt BAP combined with my OEM ('05) fuel pump, most of which was at ~560-570 rwhp.
No worries man, your good to go. Anyway, your gonna need the extra cash for new rear tires.
Good luck!
Mike
Old 06-25-2014, 08:45 PM
Streetk14
Streetk14's Avatar
Originally Posted by m_LeDez
Shawn,
Good luck!
Mike
So does he have the Magnavolt? I was assuming he didn't get it with his used kit.
Old 06-25-2014, 09:25 PM
spaulsen
spaulsen's Avatar
I did not get a BAP. Thinking I may just do the z06 pump. I dont like being that close to a maxed out fuel pump.
Old 06-29-2014, 12:26 PM
spaulsen
spaulsen's Avatar
Sunday Bump
Anyone installed a z06 pump in a base c6? If so was it a direct fit? Details please.
Old 06-29-2014, 01:16 PM
Streetk14
Streetk14's Avatar
Sunday Bump
Yes, it's a drop in. That or a BAP will give you the extra headroom you need, but the Z06 pump install is a much bigger pain to install. That's the reason most guys go with a BAP to start.
I had a Z06 pump AND that BAP/Racetronix setup on my last build. For a mild setup, one or the other is plenty.
Old 06-29-2014, 02:27 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
I was running a Z06 pump, KB Bap, and racetronix harness to about 650 rwhp with no issues. I just added an ECS stage 1 fuel system to that for more fuel under boost.
For your power level I would either go with the BAP and harness, or just add the ECS system, depending on how much you want to spend, and whether or not you plan to go to more power later. Adding the ECS system is much easier, and therefore cheaper than dropping the tank to change a pump. (unless you are doing it yourself)
To Magnuson blower/fuel question
Old 06-29-2014, 03:15 PM
scottg
scottg's Avatar
Have a Maggie Heartbeat and pullied down to second from smallest size. And had to add a kb/bap. 559.5 rwhp 539 rwt. 590.00 for part install and dyno-tune. To replace the pump for a z06 in my base c6 was 2500.00. Boost comes on at 3lbs. At 9lbs at 6400 rpms. works great. 655 at crank.
Old 06-29-2014, 08:13 PM
spaulsen
spaulsen's Avatar
How much power were you making on the BAP? My car is 100% stock and do not plan to tear it apart to make crazy power. Will most likely stay around 600hp. Im pretty sure the maggie I got will only make just over 500 will my stock car. Will the BAP be enough for that?
Old 06-29-2014, 08:32 PM
Streetk14
Streetk14's Avatar
I had that BAP on a car making 660 rwhp, though I did have meth injection that was taking some load off the fuel system. Stock fuel pump with that KB BAP and Racetronix harness should have no problem supporting 600 rwhp -- probably more.
An LS2 with a 112 blower probably won't make any more than 480 rwhp. You'll be very much in the safe zone with a BAP.
Quick Reply: Magnuson blower/fuel question
