max E85 hp using bosch 127lb/hr injectors?
I have a set of Fuel Injector Connection Bosch 127lb/hr (@4bar) injectors and I'm trying to get an idea of how far they'll take me on E85.
127lb/hr @4bar = 110lb/hr @3bar
http://www.deatschwerks.com/resource...ure-calculator
Looks like at 100% duty cycle w/ the blower and E85 I could support ~1,235hp at the crank.
http://www.deatschwerks.com/resource...tor-calculator
1,235hp = ~1,085whp
Are those calculations pretty accurate?
1,235hp = ~1,085whp
1,235hp = ~1,085whp
1,235hp = ~1,085whp
because other wise you will be getting another set of injectors next time you turn it up.
ID2000s or FIC 2100 and be done with it.
Seems low. I made 1048 at 75% D/C on ID1000s and pump. I know others have squaked out 1000rwhp on ID1000s and e85 with rising rate regulator. I would expect a 110lb an hour to make 1100+ if the fuel pressure what there to support it.
i made 1109 with FIC 1000s hitting 88% DC on 93... now i have 2000s...
I guess I have room to crank the base pressure if I wanted to.
I used the Semens 2300's because of no issues with E85 and they were considerably cheaper. I keep hearing about issues with the ID's if you let it sit even a very short time.
The bosch 2000s are high impedance and ls3 height, I'd go with those before injector dynamics
I think I'm going to try to push the 127s first though. I could run 70psi base pressure and still not pass 100psi on the boost reference fpr at max boost. That should give me some room.
As far as I know it is only the ID2000s that have issues letting them sit with ethanol. The rest are fine.
