Build v2.0
#241
My z51 calipers are the same as base, the rotor is just larger with the mounting bracket to match. I have base c5 brakes from my road course days, so maybe I'll have an easier time
#242
Yes, you grind the base c5 brakes. Also have to be careful where the wheel weights are on the rims because they will hit. There is very very little clearance.
#245
I will not cut with a wheel, Use a sawzall/hacksaw. Then finish up with an aluminum bur bit on high speed cutoff tool. Sand smooth after that.
#247
#248
speaking from personaly experience LOL! I would use a sawzal for the majority and then a tiger disc to finish it off and all of that should take about 20 min for both sides. I did a little at first and then found out that the arm articulates a whole lot so you have to set it on the ground to get an accurate look at the clearance. Also flipped the bolt on the lower shock from going in the front to going in from the rear as the end of the bolt was so close it was questionable.
#250
I had mine ground down so it cleared with a 1/8" clearance between a-arm and rim but when I got into the 1.50 sixtyfoots it started hitting again... Didn't have to cut as much as your pics show tho...
#251
When I get home I'll get some pictures of mine. Had to redo it 3 times because I kept knocking the wheel weights off. The caliper also needed a lot more than that picture shows.
#252
Again, this blower is NOT for people making less then 900HP.
The standard A and C are good for that. The F-1A-94, is a rock start on the big end.
#254
The impeller changed drastically, and the volute changed even more. However its hard to see that from the images shown. If you could see them side by side from the "front" you will see that.
#255
I really like the idea of having a step up from a YSi and still being able to fit it under my stock hood without a bunch of tricks, this blower sounds like the possible solution.
#257
you can get away with not taking as much off the lower control arm by having a shop balance the wheels to the inside lip with hammer on weights... no one will ever see the hammer ons on the inside lip and you don't have to worry about knocking the stick ons off.. been there done that way to many times.
#260
Torque seems way low.
Caliper picture I promised
https://lh6.googleusercontent.com/-u...1025141452.jpg
