Build v2.0
#81
I've used the same hose several times. Sometimes it can be a bit tight. If you have a heat gun that is best, or borrow a hair dryer from the lady. Heat the tube end just enough to be able to get it over the connections. Then let it cool. Just be sure your clamp is over it before pushing on obviously... crimp the clamp, and call it a day.
#86
Yea, may just need a bit more heat. You'll need enough to get the tube to form around the barbs on the connections. There are also some small rings on the inside of the tube. Usually 3. A big gap between 2 towards the tube end, and small gap between the inside 2. Push until the barb is in the small gap and put the clamp on the big gap.
#88
http://www.racetronix.biz/itemdesc.a...T%2D90&eq=&Tp=
I've used both. The 8.5 definitely goes on a bit easier, but only comes in one length. If the length works for your setup, then may try that if you don't want to heat the 8mm up any more.
#90
#95
Didn't get much done this weekend... had to swap my front leaf spring because my bolts were seized and the car was slammed way too low with the blower and iron block. On the motor side I mocked everything up and checked alignment and fitment, but forgot I didn't have a socket for the balancer bolt and the stores were closed. The flywheel is installed and locked, so I'll drop the motor in after I torque the bolt (feels like I've said that too many times )
I had to use the Edelbrock 8896 water pump to fit the wider 10-rib belt (I have no idea how guys get the ls3/ls7 water pumps to work without massive belt overhang):
For the belt to fit I had to grind down the '8896' casting on the front of the pump:
The coolant port is also in a different spot than the ls3/7 pumps and has a large casting chunk that interferes with the procharger bracket. I had to grind the corner down:
I don't know what I'd do without my laser alignment tool, it took a few shims behind the blower pulley to get it lined up with the crank pulley:
#99
I have a good 1/4-1/3" of clearance with my fuel rails and aeromotive fitting. It really depends on what rails you have.
#100
What rails do you run?
This looks like it'll work fine and its hard to beat the price of the Holley rails, but I think some companies mill down the rail to not waste space
