What's needed to drop a walbro 450 into the stock fuel bucket?
#42
Does anyone know what ID hose is needed? Will this work: http://www.jegs.com/i/Gates/465/2709...FVFk7AodziAAtg
#43
so what i hav gathered from this thread so far is - if only installing one 450 pump
the stock car harness will support the pump. the racetronix harness is unnecessary
no need to upgrade the wiring inside the bucket.
no need to install an aftermarket regulator or add a return line
get the 200mm tube bc the 150mm is to short or get a submersible fuel hose- comes precut to 12 inches
the stock bucket needs to be modified
drop the tank. pull the stock pump assembly out. remove stock pump. install the 450 pump which involves bucket modifications. install pump assembly back in tank. install tank back in car.
is this all correct so far.??
#45
im still working on mine but this is what i have so far..the red circle shows the stops i shortened. they allow the inner plastic piece to be lowered. the corrugated hose i got from racetronix is a bitch to get on. i ruined the 1st one. i have another on order as well as a submersible hose. i can post more pics when i get more parts
#46
#47
im pretty sure its the 5/16.. http://www.jegs.com/i/Gates/465/2709...ductId=1534981.. i can let you know for sure when mine comes in
#52
#53
I believe the small line is a bypass line that is used to keep the bucket full. 450 does not have an internal check valve AFAIK. I had to add one to keep my pressure up after shutoff so the car starts easier.
#54
#55
Can some one please messure the resistance on the walbro 450 pump? How many ohms?
and can someone please help me this this -> https://www.corvetteforum.com/forums...fuel-pump.html
#56
I've been doing a lot of reading on this and would like to clarify/confirm my understanding in two areas:
1. Modifying the bucket. It looks like since you guys put (fairly large) holes in the bucket and talk about cutting the line shown below (orange arrow), that the drivers side venturi pump will now be disabled. Is it really impossible to mount the pump inside the bucket such that this system is kept intact? I've also read that the walbro 450 pump itself has no connection for this line, but from the diagram below it looks to be part of the fuel lines, not the pump.
2. Adding a return line. I'll be doing this to maintain control over the fuel pressure. This means I have to put the caps on BOTH regulators right? One in each tank. Also, when you run the new line, how do you plumb the return back into the tank? Put a new hole and fitting in the top of the gas tank?
Thanks for your help on this guys. Lots of excellent info here.
#57
The plug is needed on the driver side. You're replacing the internal regulator with a block off because you're adding an external regulator in its place.
The regulator on the passenger side simply controls when the siphon works. It's set to transfer fuel between tanks at ~54psi. If you need to run your externally regulated fuel base pressure below 54psi you need a bypass (not block off) that will allow fuel transfer below 54psi
#59
i used
http://www.lingenfelter.com/mm5/merc...egory_Code=C78
for the retun line i uses the ECS sump..
