A&A S/c intercooler and front tow hook
Has anyone installed a front tow hook on a c6 with the newer style a&a supercharger system with the ram air style intercooler setup? I wanted a Phoenix removable hook but the mounting block looks like it may not fit with the angle of the intercooler, plus it may block some airflow. So I then considered the Pfadt style or VMS tow hook, but some others have hinted that it may not fit with the intercooler mounting position. Any thoughts?
Just installed a VMS tow hook on my 2013 gs with an a&a s/c kit. Had to modify the lip on the back and drill an extra hole for the second Just installed a VMS tow hook on my 2013 gs with an a&a s/c kit. Had to modify the lip on the back and drill an extra hole for the second bolt since I had to widen the original second bolt hole towards the inside of the car to fit loosely over the intercooler mounting bolt. Also used washers as spacers for the bolts since the lip of the intercooler bracket had to fit under the tow hook mount. I'll post picks when I get a chance.bolt since I had to widen the original second bolt hole towards the inside of the car to fit loosely over the intercooler mounting bolt. Also used washers as spacers for the bolts since the lip of the intercooler bracket had to fit under the tow hook mount. I'll post picks when I get a chance.
