C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
700+ rwhp 93 octane daily driver C6 Grand Sport build thread
Old 08-04-2014, 05:29 PM
Patrick G
Patrick G's Avatar
Default 700+ rwhp 93 octane daily driver C6 Grand Sport build thread
I have always enjoyed driving my cars daily rather than having them as dedicated race cars. I am very pleased to report how nicely my 2013 Corvette Grand Sport has turned out. First off, mine is a heavily optioned automatic car. Now before any of you purists dog the car for running an automatic, I must say that this is the fastest shifting automatic car I have ever modified. The shift response after engaging the paddle shifters is immediate.
Here are the details on the car:
Forged 416 LS3 built by LME featuring Wiseco 15cc dished pistons, Callies Compstar rods, and Callies Dragon Slayer Crank. Static compression is 10.0:1.
Cam choice: 222/242 .629/.604" 121LSA +5 advance custom Patrick G cam ground using EPS lobes from Cam Motion. This is a smooth idlling, wife-approved cam that idles at 600 rpm and sounds awesome. Good fuel economy and not a stinky cam.
HK Racing Engines sourced the Trick Flow 255 LS3 heads which were massaged by Greg Good from Houston.
Peak flow numbers were 409cfm at .650" on intake and 263cfm on exhaust. I used the TFS 448lb dual valve springs with Ti retainers. Greg worked primarily on improving the wet flow of the TFS heads as their dry flow is already excellent right out of the box.
Presence Distribution sourced the East Coast Supercharging Paxton Novi 1500 supercharger with restrictor removed. This is the most OEM looking and fitting centrifical supercharger that I've seen for the C6s. With my generous head flow, cam choice, and extra cubes, peak boost is only 11 psi. The fuel system upgrade is the ECS stage one fuel system that utilizes an inline Bosch pump activated by a Hobb switch at 2psi. This is good for over 800rwhp. No boost a pump for my combo. The stock LS3 intake manifold used the stock fuel rails and FIC 850 fuel injectors.
LSX Performance Dyno Tuning sourced the American Racing 1 7/8" long tube headers, no cats and stock 2.5" OEM NPP rear muffler section round out the mods. Kurt Decker applied a really trick Lingenfelter window switch to control the NPP exhaust so it stays closed and quiet at any rpm where throttle position is less than 80%. Above 80% throttle, the extra baffles open and it gets really loud and exotic sounding. I have the mild to wild switch if I want it to be loud all the time.
Assembly of the engine, supercharger and fuel system was handled by Mike Pabone at Late Model Racecraft in Houston. LMR also fabbed up a custom coolant crossover for cylinders 7 & 8 to keep combustion chamber temps in line with the others. LMR also constructed a trick dual hose evac system to keep crankcase pressure under control and to route crankcase gasses to a catch can reservoir at the front of the car.
All tuning was handled by yours truly using both EFI Live and HP Tuners. There are some really important tables that are exclusive to each piece of software so the best tune came from using both programs.
On LMR's dyno, the combo made 719rwhp and 653 rwtq. Here's a video of the dyno run.
Keep in mind, this run was performed with only 15 degrees of spark timing, 93 octane, no meth, and 11 psi. Don't forget this is an automatic with stock transmission and stock torque converter. If I want to make over 800rwhp, all I have to do is do a pulley swap, add some race fuel and crank the ignition timing up into the 20 degree range. I plan on racing the car in this upcoming Texas Mile. The car is a highway machine, it gets 23mpg and is super reliable. I give thanks to all parties involved in making this project a reality.
Old 08-04-2014, 05:41 PM
y2krtaf
y2krtaf's Avatar
Absolutely love it!
Old 08-04-2014, 05:51 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Nice build. Loving my cam you spec'd for me.
Old 08-04-2014, 05:52 PM
Detoxx03
Detoxx03's Avatar
Nicely done Pat. Cam Motions quality is awesome (all Futral uses) and you know how to keep things simple.
Old 08-04-2014, 05:59 PM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Killer build Pat!
I love the auto Grand Sports...
Old 08-04-2014, 06:11 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Very nice build and combo. Also very happy with the cam you spec'd for me during my build.
Old 08-04-2014, 06:17 PM
0Presence Dist.
Former Vendor
Presence Dist.'s Avatar
Looking good pat... next up is dewitts radiator and dual fan setup. Let me know when your ready.. the BM special lol
Old 08-04-2014, 09:36 PM
venomws7
venomws7's Avatar
Amazing build congrats Patrick very nice combo.
Old 08-04-2014, 10:18 PM
Slo-Poc
Slo-Poc's Avatar
Clean and simple, I like it
Old 08-04-2014, 11:53 PM
lt1z
lt1z's Avatar
Nice Build!
Old 08-05-2014, 04:35 AM
Pitufina
Pitufina's Avatar
Patrick, first of all thanks for sharing! Yours is the type of car when I think the definition of a sleeper. One thing I noticed, that got my attention is that you didn't use Injectors Dynamics. I would think a person like you who's well known as a tuner and cam guru like you would only use the "best". Do you care to elaborate of why you chose the FICs?
Btw, I think that Mike may have spoken with you about a cam for my future ECS intall. I think you understand what I'm looking for considering your own cam specs on that beast. Obviously I'm still on the stock LS3, but want basically what you just described on yours as far as docile, valvetrain longevity, non bucking/surging and finally wife approved lol
Old 08-05-2014, 06:52 AM
08C6
08C6's Avatar
Super awesome build... " lots " of horsepower to play with !!!
Old 08-05-2014, 07:50 AM
BOO666
BOO666's Avatar
I love it !
Old 08-05-2014, 07:56 AM
camirocz
camirocz's Avatar
This is the way street machines should be modified.Nice and tame while going for a cruise and a low 10 second terror on the track.Good job.
Old 08-05-2014, 12:39 PM
CUSVT
CUSVT's Avatar
Awesome build. Glad you feel that way about the A6 as far as shifting. Once they are dialed in they are hard to beat. EFI Live helped tune mine in as well. Congrats!
Old 08-06-2014, 09:11 AM
0Presence Dist.
Former Vendor
Pat tunes some of the fastest 6l80 vettes out there!!! He knows what he is doing and learned alot about them over the years.. Only one i recommend on tuning them
Old 08-06-2014, 09:17 AM
CUSVT
CUSVT's Avatar
LIKE
To 700+ rwhp 93 octane daily driver C6 Grand Sport build thread
Old 08-06-2014, 05:14 PM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes on 656 Posts
Very nice!!
Old 08-06-2014, 10:54 PM
rio95
rio95's Avatar
Is ve tuning the reason you used efilive? If so have you had luck with blue cat? Sweet setup by the way!!
Old 08-07-2014, 07:18 AM
Patrick G
Patrick G's Avatar
Yes. Being able to build a proper 3 bar MAP within the factory OS is a really nice feature of EFI Live. Blue Cat can be just as effective if you follow all the steps and don't take shortcuts building your boost table.
Quick Reply: 700+ rwhp 93 octane daily driver C6 Grand Sport build thread
