Am I the only turbo 4.8 C6 in the world. Lol
#41
Ya Frank it does feel a little sluggish but once the boost comes on you forget about it.
We might turn it up a little this weekend and install an Eboost2 to bring the boost on a little sooner.
If I get bored this winter I'll be swapping the little 4.8 for a 6.0L to take care of the lag. My old setup was making 12lbs of boost by 3500 and this is only making 3-4lbs. It would be nice to not have to down shift to make some power.
#43
very cool, only 4.8 in a c6 i have seen yet. but the 4.8 & 5.3 are so cheap and strong they get jammed in everything here in houston constantly see these things making 750+ rwhp and living for a surprisingly long time. and yes several nearing 1000 hp and last at least a season. truly the only down fall to these motors in the weight, but that is also part of what makes it so desirable the cast iron blocks are so strong
#45
The car is down for the season Needs a clutch and new hydraulics. I was trying to setup the eboost 2 and I had a 19lb boost spike. Spun the clutch right away. Time to order a McLeod rxt.
I found a really good deal on a 6.2 so I will be removing the little 4.8 over the winter.
Very excited to how it does with the 76/75. It's should spool up instantly
#47
Was thinking about selling it but I'm on the fence right now about building a big NA motor.
I daily drive it on nice days in the summer.
#48
Eboost is easy once you figure out the number for your boost setting is not boost, but the number of pulses to achieve desired boost level. Sounds like you had a ton of **** barely working or on its last leg. GL with the new motor etc...
#49
Eboost solenoid was bad. Need to order a new one. Buying stuff used can suck sometimes. Good deals are not always as good as they seem.
#51
On a turbo build I put together a while back. I had to use a flexible lokar dipstick. It was also one of the universal 1/8npt end. I tapped the block. Engine was on a stand still. Tho. And coincidentally it was a gen 4 4.8 that's punching out 690rw thru a th400 and built 8.8 rear. On pure pump gas. Not even meth. Just a 100$ eBay fmic.
I love these motors. My rcsb is a turbo 4.8 dd also.
I'mshopping for a c6 now. And dropping in oone of a 4.8 I got laying around w a 7875 t series. If it pops no biggie. Id rather not blow up an ls3 or ls2 engine.
#53
I m from the fbody world and theirs more than a few guys that make 800+rwhp on the stock bottom end. Another guy on ls1tech.com hit 918rwhp with no2 in his Silverado that towed his boat. Those little 4.8s can make huge power. Btw I love that you have a 4.8 in a c6! My bro keeps telling me that I m going be the first one to do this when I blow my ls3 bc I d be to cheap to fix it. Good to see another who thinks outside the box
