Wtb zex window switch
That looks identical except for the wiring. The one I'm looking far only has 5 wires. 2 white,one black,one green and a red. Do you have a part number on that? I hope it works the same. Just confused on the wiring.
I finally found and purchased a brand new left over one from Travis at 5252 motorsports. You definitely have a window switch. If you want you can contact zex tech support and they may be able to identify the wiring then you will know what you have. It definitely looks like a zex window switch. Zex tech line number is 888-817-1008. I would give them a call and tell them u have a part that's identical to there rpm window switch that's discontinued but the wiring is different. They should be able to help you that way you know what you have. I appreciate your help. I would have def tried to buy it from you if it had a diagram.
I did some research for you. You seem to have a nitrous outlet digital window switch. Part number is NO-00-6100. Wire color is:
Blue- TPS WOT input wire
Green- RPM or TACH input
Orange - controls second stage relay
Yellow- controls first stage relay
White- to keyed 12v source or arming switch
Black- ground
Here is a link of superchevy installing it on a ls2 C6.
http://www.superchevy.com/how-to/vemp-0902-c6-corvette-nitrous-system/viewall.html
Black- ground
Black- ground
http://www.superchevy.com/how-to/vem...m/viewall.html
Black- ground
