Hot Start Issues
Hot Start Issues
2011GS with a cam and a&a kit experiencing some intermittent hot start issues. Attempting to restart a warm engine (even hours after it has been shut off) and car needs throttle to fire up otherwise it just stalls out. It has done this in the past but I attributed it to the hot temp. It happened again tonight and it was pretty cool out. Anyone else experience this? Any input? Is it tune related?
Battery and starter are the first places to check. If it has headers then wrap the starter to protect it.
Buddies car with an A&A kit and fore fuel system was doing it. What we found was that the fuel line was getting air in it from boiling the fuel and the battery was too weak to prime the system quick enough. He put a deep cycle marine battery in the car and it almost 100% eliminate the problem.
It cranks just fine, but fires up and sputters/stalls, right? If so, it's likely something tune related, and nothing to do with the starter or battery.
If you have an aftermarket fuel system, then that'd be the first thing I'd look at (i.e. fuel pressure dropping). If it's a stock system, it can likely be cured via tuning. I had a similar issue after installing my A&A kit. It's a mystery what caused it in my case, but I was able to cure most of it through tuning tweaks. I'd still start with making sure you have good fuel pressure when this is happening, though.
It has stock fuel system with 60 lb injectors. I spoke with the tuner and he said that it has to do with the crank fuel/air needing some adjustment.
I'd have to agree. In your case, it probably needs more air while cranking. I really don't like the drilled out injectors that come with most of these systems, but that's a whole 'nother discussion.
exact same problem with my SC Z06. I actually changed to a 1 step colder plug and found it helped. It's tune related. I found my car was choking itself out when I was trying to start it. smelled like heavy fuel. spuddered and shaked and wouldn't start. Only happens when It's hot. I also have 60 lbs injectors on stock fuel system. good to know it's not just me. lol I'm getting a new tune soon.
