School Me On Guibos
School Me On Guibos
Had a driveline failure at the track Saturday night. Loud bang and then it would just coast. Problem seems to be ahead of the diff and I'm leaning toward a guibo failure as I've never been inside the torque tube. I'll know today.
If it is a guibo what should I replace it with? Poly? ZR? I don't want solid.
I would do the DSS poly couplers. I just recently rebuilt my TT with those and the RPM bearing kit along with a DSS 3.5" Alum shaft.
I popped a G Force mainshaft in my MN12 Trans when I still had stick Trans at the dragstrip..
TR6060 should hold a lot better...but the drag strip WILL find the weakest link...
Race cars > Dyno queens
snap ring is no problem at all with the correct tool. RPM Poly couplers are the way to go.................no problems since installing them.
Bill, from the urban dictionary:
A nerd. A highly educated person (technology) with impaired social skills.
Proto makes a great set of snap ring pliers that will pull the snap ring out in less than 10 seconds.
Pulling it out was cake, putting it back in took some effort. My snap ring pliers just didn't want to work on one that big and strong. Kept popping off. I did it, but took a few tries.
St. Jude Donor '13
The 3.5" DSS alum shaft with poly guibos is great way to go. We do a lot of the poly guibos by themselves too, but you are making some steam on your build especially with the twins there.
DSS also has a nice carbon solution that does not require guibos also.
St. Jude Donor '13
Hard to say.. I have had stock cars toss guibos before, and I've had 800+ rwhp cars hold together... Really no good way to check besides listening for vibration while on dyno, besides pulling it apart. You'll know when you undo the torque tube and 2lbs of rubber dust comes out that it's time to replace!
