Tuning is this week, RHS 447 on crack
Awesome build man the setup gonna be nasty.
2 things why not more compression since you have E85? And why not bigger cam?
My guess is 620-630rwhp 540-550rwtq N/A Never saw a good results from this Wilson intake maybe in the future you can swap to Precision Metalcraft Intake those are SICK.
845rwhp 890rwtq 200shot
Keep us posted.
Keep us posted.
The old setup made 617/575 with this same motor, intake, and cam, but different heads, fuel system, headers, etc...and it never was on spray then. I'm not too worried about the intake manifold. It seems that any manifold that fits under the stock hood will be hampered compared to a longer runner length or blow through manifold, but I don't want any holes in the hood. They likely gain nothing compared to a nice ported FAST 102, but they look so damn good.
_Sloth Whisperer_
Pump fuel, I'm going to guess 615 on a Mustang, 645 on a Dynojet. With E85, bump both of those by about 30hp. Of course this is tuner-dependent as far as how they they want to take advantage of the fuel.
That 200 kit will send it into the 860 range for both whp and lb-ft.
Just guesses.
Just guesses.
Just got a text from the shop.
615/554 n/a
810/796 200 shot
This is on a load bearing dyno, not a dynojet. Not as high as I was hoping, but dyno's are just tuning instruments, we'll see what the track results say when she visits it soon. Hoping for low 10's on motor and low 9's on spray, but obviously that is dependent on the driver.
615/554 n/a
810/796 200 shot
615/554 n/a
810/796 200 shot
Thanks for the update
real solid numbers to work from and keep us posted on track results.
810/796 200 shot
#36
Those billet wilson intakes suck.
I think that will hold you back on that setup.
We built a c5 a few years back
440 ls7 built for 350 hp of N2O
All pro heads 11.5:1 compression
Custom nitrous cam
fast 102
NW 102
17/8-2 inch step headers
tr6060 c6z rear
It made 620 rwhp on break in tune.
Then a buddy built the same motor but used the wilson and it was 20 rwhp down peak difference from 4500-7k rpm
Custom nitrous cam
fast 102
NW 102
tr6060 c6z rear
#37
Custom nitrous cam
fast 102
NW 102
tr6060 c6z rear
Custom nitrous cam
fast 102
NW 102
tr6060 c6z rear
I may be selling my valve cover setup already, so I may sell the intake manifold and fuel rails as well while I'm at it and really de-bling the engine bay.
#39
So what intake manifolds are available to make the best power for an n/a or nitrous car that will still fit under a stock-ish hood. I have a slight bump in the hood, but I'm not cutting it open to fit a blow through carb style intake or anything. If/when I decide to go with a turbo setup, I may reconsider my options, but for now it will stay just a nitrous car, but I may add a 2nd stage here soon.
#40
Personally, I have a hard time believing that Wilson intake is a restriction... Although I have never tested one, we have used Wilson on our old big block stuff and they always perform outstanding..
I would have to see an intake swap on the same car, same dyno, same day to believe its less efficient..
Different cars on different days, useless data...
I'm sub'd for your progress.. 2nd kit gonna be nasty!
