What went wrong??Supercharged my C6 and blew motor on dyno.
#81
I had about 20K miles and more than a few trips down the qtr. mile on my ZR1 clutch. That's behind a Maggie at 650rwhp along with all that stupid *** Maggie torque. No problems. And when I be shiftin' on the streets, sumtime I be shiftin' hard too I hope every clutch that I own from here on is as good as that one was...and still is. I sold the car to a neighbor and he's lovin' it too.
#82
Oh no they are that bad. It's the worst $1600 I've ever spent and worst mod I've ever done in my life. Everyone I know that's had one it started slipping and not shifting after a few thousand miles. It's great if you do nothing but just drive but anything else it's garbage.
Grab a Mantic, RXT, or RPS!
Maybe it's a luck of the draw sort of thing with that clutch? I dunno.... but I think if it's treated like an OEM clutch it will last a long time. If it's being raced every weekend, then it probably isn't the clutch of choice.
#83
Once again, AWESOME ADVICE from everyone. Gotta say I am bumming on the clutch comments as it's already here. Thought I bought the best one out there for my needs. Was just going for good drivability and something that could handle the HP. All the other reviews (not on this site) that I could find were pretty decent.
#84
I think you need to slow down and do some more research before making any decisions. A few more thoughts for you:
1) If it were me, I'd keep the stock compression ratio. There is really no reason to lower it. You'll just make the engine lazier when not in boost and hurt fuel economy. I've seen guys do it and regret it big time. Stock compression and 10 psi work fine together on pump gas.
#85
#86
I would sell it and buy something else. The ls9, if it was $600-800 maybe would be ok for a lower HP car. Your new build should be 700-800rwhp easy if you do it correctly and there are just better clutches for the price. Mantic, RXT, LT1R, etc.
#87
Like Unreal said I'd return it and buy a real clutch.
#88
So the motor lost several ring lands and closed the gaps on the plugs but graph does not show any dropping of cylinders.
I would bet this IS NOT the graph when motor let go.
#90
Received 1,194 Likes
St. Jude Donor '15
Please don't let them blow this one up too. It'll probably survive more "inexperience" than the last, but they can kill it just the same if they don't know what they're doing
(good luck, hopefully it goes well..)
#91
No doubt, I definitely agree with you. The owner of the shop is doing all the work on this one, and the guy who was tuning it is no longer there. This time, the responsibility is all on them, so I am very confident that they will take the utmost care and tune on the side of caution. Due to the clutch break in period, it won't even go on the dyno for a while, just data logging on the street with me driving at less than 50% throttle. Keeping the AFR's in the 11.5 range per everyones suggestions. I'll be running 92 octane with 32 ounces of Torco to 18 gallons of gas from now on, and keeping the boost to 10 psi max. When all said and done, I'll be into this thing for a little over 20 grande, I will take no chances with her.
#92
#93
St. Jude Donor '15
#95
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
Glad to hear you're happy with the Mantic twin!
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
#96
Clutches don't mind WOT. I would get it on the dyno as soon as it heat cycles and leaks are fixed. My motor has 12 miles when it hit the dyno. Clutch won't care about WOT pulls, just launching/engaging/etc.
#97
Some times you just have to give up on someone because they are not taking advice. That is this thread. There is NO WAY IN HELL this shop should be attempting such a build. They have NO CLUE what they are doing. They are pushing for MAX results with ZERO care for the owner's wishes. He wanted to be slightly conservative and they went max effort in a dangerous way, either because they don't know what they're doing or they're wreckless and just wanting some obscene HP number to use for marketing.
Now the wrong clutch is going in the car for the build. Clutches are a PITA, do it right the first time! The simple fact the shop said ok to a ZR1 clutch into a 408CI supercharged motor @ 10 lbs is silly..... unless they want to bust your *** for labor in a few months on a new clutch......
I give up!
I give up!
#98
I give up!
I give up!
#99
St. Jude Donor '15
#100
I give up!
I give up!
I do think there are better options these days, but I also think there isn't too much to worry about as long as he doesn't beat the living crap out of the car.
I used to run the NOS Racing Formula octane booster (which contains MMT like Torco) in my twin-turbo BMW to help supplement our crap 91 octane, but stopped doing so after I saw what the inside of my turbos looked like after running. I'm sure it takes a while for any harmful affects, but it wasn't something I wanted to keep putting in my engines after seeing what it did and doing some reading on it. It's actually a metallic coating that accumulates as the MMT is burned.
Ethanol is a better octane booster IMO. There is obviously more cost involved to safely run E85 blends in an LS motor, but it's a better choice in my opinion.
