5 point harness installation
Not sure where to post this question, but since I spend most of my time here, I chose to post it here.
I have the RSD 6 point rollbar.
Converting my stock seats to have a pass through for a harness setup.
What kit or what do i need to install a 5 point harness?
Also is there a harness people recommend that is more comfortable than another? Way too many options for harness' out there
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
I just bolted my harness in. I made a bracket for the left side lap belt going through the oem retractor bolt. The right side lap belt I bolted in between the factory buckle/seat. The threads are long enough. The crotch belts I bolted to the front of the seat frame on each side... I didn't use a T bracket like most do. Works fine for me. Pretty much all of the 5-6 point harnesses mount the same and have eyelets on the ends. There is some nice brackets companies make for C5 mounting but....$$$.
I also modded the seat for pass through.
Yea finally got everything road ready. I really expected 50-75 more to the wheel. But all good, just happy to be able to romp on it whenever i want.
Well, what were the numbers? I'm sure whatever it was it is fairly useless on anything but a heated DR.
