fuel pressure gauge install HELP!!!
07 Z06 trying to install an autometer full electric fuel pressure gauge with an E_force SC and with the aftermarket fuel rails don't have a Schrader valve. Is there a fitting I can use to T off the fuel line ?
Hinson has a Russell fitting that will help you out!
http://www.hinsonsupercars.com/p-105...side-port.aspx
Wasn't the exact same fitting but did use that plastic clip. ( whatever they call it )
In this thread you can see what happened, and with what I replaced it.
https://www.corvetteforum.com/forums...new-build.html
hey bro what exact part can I replace the russel 640730 fitting with that will work? will that swedgelok work on my fuel line? do I need this as well-Russell 644003 I'm really useless when It's comes to fuel line fittings, But I don't want no gas leak. All I'm trying to do is install a fuel pressure gauge. nothing fancy.
Sorry I cant help more on that.
