BTR Valve Springs & Stock Cam Overkill?
I am closer to return home from my deployment and I've been planning my ECS kit install. I had in mind replacing my n/a spec'd cam with a more friendly blower one. In fact I received a couple of recommendation from two of the best cam gurus, but lately things have not being going well in the budget department due to several unexpected situations.
There's one thing I still can't stand from my current cam and is the constant smell of fuel. My wife hates it with passion too lol It gets inside the car when I turn the a/c or heater on and of course it gets on my clothes and so on. It sucks to arrive to work or party smelling like junkyard
So, since it looks like I may not be able to afford that new cam I was thinking on reinstalling the stock one, but my concern are the valve springs. I really don't want to use the stock ones with boost for peace of mind but at the same time it causes me to think if there are any problems that can emerge from that. What about the pushrods? Any insight?
Edit: I think I'd be picking up cans on the side of the road to afford a new cam. Comp grinds are about $350 delivered if you buy from the right source. Maybe buy your wife a gas mask until you can afford a new cam.....
I would figure out why the car stinks. I run no cats, and a decent cam and no issues. Could it be a leak or purge issue? That or the tune? No reason a cam should make the car smell of fuel.
If you have BTR springs, I'd call BT and get his take on what you're doing. Can't imagine there being a problem though. I'm assuming you're using aftermarket pushrods. Are they stock length?
LOL not a bad idea for extra funds. In reality is not that I don't have the money, is that it's going to be so much harder to get the go ahead from the wife with all the late expenses.
Shoot, Arun told me that my cam would work great. I still think is too much for what I want or need.
See above. It may be the exhaust.
Thanks for the suggestion though.
